SOME ONE HELP!!!!! please
Old Jan 14, 2006 | 03:41 PM
ITRPNP's Avatar
Default SOME ONE HELP!!!!! please
I bought this head but i'm not sure what head or should i say from what motor it came out from. the casting code on it is pr3-4.... my friend has an 99 si and it says pr3-2. my other friend has an sir it says pre3-1. this kid has the same head as me but he doesn't know what motor he has. so can someone help me out cuz some people says that a type r head some doesn't...The intake manifold that came with it not on it says P73..so i don't know
Old Jan 14, 2006 | 03:53 PM
da6jdmteg's Avatar
Default Re: SOME ONE HELP!!!!! please (ITRPNP)
pr3-4 could be a b17a1 92-93 gsr or a 95 up type r
Old Jan 14, 2006 | 03:56 PM
da6jdmteg's Avatar
pr3-4 could be a b17a1 92-93 gsr or a 95 up type r.
not the same head but the same numbers. if the manifold is upside down its gsr. normal. type r
Old Jan 14, 2006 | 04:02 PM
Dogginator's Avatar
Daisy... Daisy...
I have a PR3-2 head that is from a 96 spec JDM ITR. If it is from an ITR, it will have double valve springs on both the intake and exhaust sides, light porting and polishing at the valve seats, and necked intake valves near the valve head.
Old Jan 14, 2006 | 04:06 PM
ITRPNP's Avatar
Default Re: SOME ONE HELP!!!!! please (Dogginator)
well i bought this head with ferrea flat top valves/ferrea valve guides & seats/portflow valve springs and retainers. it didn't come with any cams so i can't exactly tell with the valve springs cuz its been changed. the guy i bought it from told me it was a type r but idk
Old Jan 14, 2006 | 04:13 PM
ITRPNP's Avatar
Also how can i tell the year of the head some people say its the 4 circles look at the first circle and its that number thats the year of the head?
Old Jan 14, 2006 | 04:26 PM
Dogginator's Avatar
Daisy... Daisy...
A B16 and an ITR head are the same casting. The difference is the valve train and the mild porting job. Your head is most likely superior to the stock ITR head.
There is a date code stamped onto the head. The circle to the left (the head is right side up) should be the year.
Old Jul 8, 2006 | 02:53 PM
1990crxsir's Avatar
Sorry to bring up an old post but I have the same problem as the OP. I am curious if anyone can tell me what year this head is. It should be from a ITR (PR3-4). Its the year that has me stumped. Can anyone help?
Sorry for the fuzzy pic.
In case its too hard to read the numbers are as follows:
blank / 2
blank / 5
2 / 0
0 / 6 (or 9 / 0 if upside down)
Modified by 1990crxsir at 6:07 PM 7/14/2006
Old Jul 8, 2006 | 06:23 PM
1990crxsir's Avatar
Default Re: SOME ONE HELP!!!!! please (1990crxsir)
bump
Old Jul 8, 2006 | 06:32 PM
Dogginator's Avatar
Daisy... Daisy...
It is probably 1990. In your picture, are the exhaust ports above the date stamp? If so, the year is to the far right.
Here is a thread with pictures of an ITR head that I sold.
https://honda-tech.com/zerothread?id=1493391
Old Jul 9, 2006 | 10:52 AM
1990crxsir's Avatar
No, the ports are below the stamp.
Here is the full size pic.
Old Jul 9, 2006 | 11:03 AM
Dogginator's Avatar
Daisy... Daisy...
Perhaps it is from 2002. Honda may have sold it as a replacement head. Perhaps some of the ITR owners with 00-01 ITRs can look at their date stamp.
Does your head have everythings else that is supposed to be in an ITR head? My previous link outlines the features. Here are some additional links.
https://honda-tech.com/zerothread?id=553446
https://honda-tech.com/zerothread?id=53660
https://honda-tech.com/zerothread?id=112096
Old Jul 9, 2006 | 11:43 AM
1990crxsir's Avatar
Thanks man. You have helped out alot. I have run down to the garage a few times checking different stuff out. The head does not have the green paint on it so I am concerned.
To be honest I have the whole engine but last time I tried to find out the info in the type R forum I was blazed by people claiming it was stolen. The VIN tag is gone but that is my fault because I ripped it off removing the engine from the pallet and my wife swept up the garage the next day throwing it in the trash. Needless to say I cannot simply check the VIN number. I want to know what year the engine is to buy replacement parts. Before I drop it in the car I want to change the timing belt and water pump but at the auto parts store I noticed they sell different parts based on the year (even though I was told all ITR's are the same). I was hoping it could be identifed as a ITR head without removing the head from the engine. Would the dealership be able to identify the year?
The flaming thread:
https://honda-tech.com/zerothread?id=1647650
Old Jul 9, 2006 | 11:51 AM
Dogginator's Avatar
Daisy... Daisy...
You can check the valve springs without removing the head. If you remove the intake manifold, you can see both the necked intake valves and the porting near the valve seats. The B16A, B16B, and B18C5 all share the same PR3 cylinder head casting. The ITR and CTR castings are hand selected, receive a mild port job, and have an upgraded valve train. If you have the valves, springs, and porting, the head is most likely legitimate.
Old Jul 9, 2006 | 04:14 PM
1990crxsir's Avatar
I haven't removed the intake manifold but I did take off the valve cover. I see the yellow paint on the intake springs and the blue paint on the exhaust springs. That makes me feel better. The only thing that confuses me is the date stamping on the head. I would like to think the [blank / 2] for the first number would be for 2000, but the more I think that just doesn't make sense.
Thanks again for your help. I don't have the mystery solved but I feel better about the authenticity of the head.
paulyg2008
Feb 17, 2014 05:25 PM
DRtools
24
Mar 15, 2009 10:32 AM
vitalik
May 15, 2006 01:45 PM
NA JDM GSR
Mar 1, 2005 04:11 PM
