code 13 and 7
I did the test on my TPS again. When I connected the red/blue wire to the outer wires it is reading 4.5 volts. I just threw my old DX TPS on not connected to the throttle body and it read the same way so I dont think the D16 TPS is bad. I ran the continunity from the ECU straight to the TPS and all were reading 0.00 ohms. Wires are good. In the mean time I ran in to a code 13 Atmospheric Pressure Sensor code. I thought that it was from when I revesed the wires for the DX TPS so I switch them back still doing it. I noticed in my manual it looks like there all interconnected. What is the APS and where can it be found. Could this be causing the TPS code also. I never had code 13 b4.
Hope ya'll can help
Randy
BTW this is a DX to SI conversion
Hope ya'll can help
Randy
