v tec not working...
Old Jul 8, 2006 | 10:02 PM
dumped4dr's Avatar
Default v tec not working...
i have a d16z6 in 2 of my cars and the vtec doesnt hit in one.
it had an oil leak next to the soloniod. i replaced the gaskets and it still wont hit, at all . anyone know what could be wrong?
Old Jul 8, 2006 | 10:13 PM
lv6l's Avatar
does it throw any codes? check that first to make sure if its working properly. and a little info, i've notice on sohc motors, vtec is very little noticable compare to dohc. good way to test is cruise on freeway at night time and drop it to a lower gear and slowly let your rpm go up to vtec engagement point and see if you hear a difference.
Old Jul 8, 2006 | 10:31 PM
dumped4dr's Avatar
Default Re: (lv6l)
it has no CEL's. and its in an ex coupe so everything is pretty much stock.
my hatch has the same exact engine/exhaust and its a noticable difference when it hits v tec. it doesnt crack load but it gives a different tone.
Old Jul 8, 2006 | 10:42 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (Nic's_JDM_EG9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nic’s_JDM_EG9 &raquo;</TD></TR><TR><TD CLASS="quote">it doesnt crack load but it gives a different tone. </TD></TR></TABLE>
WTF does that mean, exactly?
Old Jul 10, 2006 | 01:34 PM
AIRIC's Avatar
Default Re: (Archidictus)
one time i hit a bump and my vtec fell off in the middle of the road. you should check if ur vtec is this there
Old Jul 10, 2006 | 01:43 PM
-Gary-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nic’s_JDM_EG9 &raquo;</TD></TR><TR><TD CLASS="quote"> it doesnt crack load but it gives a different tone. </TD></TR></TABLE>
Old Jul 10, 2006 | 02:28 PM
tico's Avatar
make sure ur oil pressure is in code. if not then ur v-tec will kick in much l8er.also check the wiring to the solenoid. if everything is koo then have ur ECU checked
Old Jul 10, 2006 | 02:34 PM
swap_killer7079's Avatar
Default Re: (tico)
Check the vtec wire with a voltage tester and see if its giving the solenoid power, if so replace the solenoid.
Old Jul 10, 2006 | 02:59 PM
8krdline's Avatar
Default Re: (swap_killer7079)
more sure you have enough oil since it's leaking out
Old Jul 10, 2006 | 03:24 PM
instructor74's Avatar
Default Re: (8krdline)
how is your oil pessure if it is below spec then vtec will not come on
Old Jul 10, 2006 | 03:48 PM
Syndacate's Avatar
Wow...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidicutus &raquo;</TD></TR><TR><TD CLASS="quote">WTF does that mean, exactly?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gary- &raquo;</TD></TR><TR><TD CLASS="quote">?</TD></TR></TABLE>
Pathetic that these guys can't figure out what he meant, instead of "load" substitute the word "loud" and it makes perfect sense...go figure, eh?
Old Jul 10, 2006 | 04:24 PM
Unceasing Measure
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">Pathetic that these guys can't figure out what he meant, instead of "load" substitute the word "loud" and it makes perfect sense...go figure, eh?</TD></TR></TABLE>
Out of all the members of this site, you least of all should be using words like "pathetic" to describe anyone other than yourself.
Old Jul 11, 2006 | 10:15 AM
lv6l's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nic’s_JDM_EG9 &raquo;</TD></TR><TR><TD CLASS="quote">it has no CEL's. and its in an ex coupe so everything is pretty much stock.
my hatch has the same exact engine/exhaust and its a noticable difference when it hits v tec. it doesnt crack load but it gives a different tone. </TD></TR></TABLE>
he said his hatch is louder. maybe the ex sound deadners effect the noise? maybe..anybody think so? just a thing that just pop in my head. might help. good luck.
Old Jul 11, 2006 | 10:45 AM
dust_101's Avatar
Default Re: (lv6l)
pretty stock D16Z6 here as well... in messing around with wiring (gutted car+boredom) put in that LED on the A4 pin on the ECU... the Coupe just isn't all that much louder when VTEC does kick. it is a wee bit louder once you hit it (5k 5200 rpm?) but not much...
best bet is to check the voltage, or try the LED http://www.hazone.com/hvlight.htm
ej_vtec
11
Oct 22, 2006 10:56 AM
DieMaster
13
May 16, 2005 05:07 PM
chansw
Jul 19, 2004 05:28 PM
GreenEX
Feb 19, 2004 06:59 PM
99lsvtecauto
10
Oct 12, 2003 11:35 AM
