very weird electrical problem.. battery exploded
Old Jul 8, 2006 | 08:23 PM
blumpfish's Avatar
Default very weird electrical problem.. battery exploded
I started up my car today.. put it in first, let out the clutch.. car shut off first.. then everything turned on and off a few times.. then went completely dead.. i popped the hood.. the battery is hissing and spewing acid everywhere.. and the battery wires were melted.. every fuse in my fuse box is blown.. what the expletive happened?
Old Jul 8, 2006 | 08:32 PM
JJ's civic's Avatar
Default Re: very weird electrical problem.. battery exploded (blumpfish)
i think you had a wore cross or sumthing that just fing sucks sorry to hear that
bump for the misforture.
Old Jul 8, 2006 | 08:35 PM
blumpfish's Avatar
Default Re: very weird electrical problem.. battery exploded (joeny12985)
so , is everything fucked?
Old Jul 8, 2006 | 10:32 PM
blumpfish's Avatar
no one have this happen before?
Old Jul 9, 2006 | 02:16 AM
philkehn's Avatar
sounds like a bad battery, is it still hooked up, the only other thing it could be is bad connections, you should have to wires from your positive terminal, one to the starter the other to the fuse box, and its properly grounded? anything unusual you noticed?
Old Jul 9, 2006 | 03:59 AM
sierrakilo's Avatar
Lead-acid batteries can develop internal shorts which would cause them to explode... my '91 Accord did the very same thing a few years ago. The wife went to start it, and BOOM... dented the underside of the hood. Hydrogen gas is vented from the battery as it is being charged and can collect in the engine compartment, or even build up inside of a 'sealed' battery case. Sounds like what happened to you.
Old Jul 9, 2006 | 08:08 AM
fujiwara takumi's Avatar
The only time I ever had this happen was by shorting my miata's battery witha jack in the trunk. I replaced the battery and the main fuses and all was fine. What year was the battery?
Old Jul 9, 2006 | 07:10 PM
blumpfish's Avatar
Default Re: (fujiwara takumi)
I went and checked it out earlier today.. the positive terminal of the battery touched the engine bay and melted a hole thru it..... the mount came off somehow and the battery toppled over .. the ground wire for th abttery is melted but the positive wire is fine.. everything else seems fine.. gonna get a new battery and ground wire tomorrow and hope it works..
Old Jul 10, 2006 | 11:16 AM
blaze_32001's Avatar
Default Re: (blumpfish)
repost anything else that may happen also if u may need suggestions or help i wanna know how this turns out
Old Jul 17, 2006 | 10:01 AM
blumpfish's Avatar
Default Re: (blaze_32001)
replaced the battery , and battery ground wire.. everything is fine now..
it looks like the mount was loose and the battery toppled over.. the positive terminal hit the wall of the engine bay and thats when it all went to **** the positive terminal actually burned a hole thru the engine bay about a half inch in diameter
Bancas
Feb 5, 2013 03:13 AM
Tip14
Dec 27, 2007 01:13 PM
Pooby88
Jul 2, 2006 05:09 PM
braypunt
22
Sep 11, 2005 09:10 AM
