Can a B16A2 engine be turned into a Type-R?
Old Apr 19, 2002 | 03:21 PM
Si's Avatar
Si
Default Can a B16A2 engine be turned into a Type-R?
It probably sounds like a bumb question, but I was just wondering how you could make the b16a2 into a type-r. I don't know if it's even posible, but it doesn't hurt to ask.
Old Apr 19, 2002 | 03:23 PM
non-VTEC's Avatar
Default Re: Can a B16A2 engine be turned into a Type-R? (RedSi99)
probably not.........you can put alot of aftermarket parts into your B16 and make as much if not more HP than the ITR engine but it will never be a B18C5
Old Apr 19, 2002 | 03:30 PM
Si's Avatar
Si
Thanks
Old Apr 19, 2002 | 07:25 PM
91DA9's Avatar
all that a b18c5 is a stroked, PnP, b16,with a few other minor modifications. So i would say that yes a b16 could be made into a B18c5 but would it be cost effective? no.
Old Apr 19, 2002 | 09:16 PM
ElectronVTEC's Avatar
Default Re: Can a B16A2 engine be turned into a Type-R? (94IntegraGSR-OVR)
Not just stroked, its a taller block to begin with. The B16B is a destroked B18C5. I got my B18C5 bottom for about $1900 and a set of cams and a decent P&P would only run a couple hundred bucks so yea, it can be made into an ITR motor but trust me on this, it aint worth $2500... EV.
maintain
May 20, 2008 09:12 PM
JadedSol
12
Dec 30, 2004 02:20 AM
DICKE
Mar 21, 2004 06:23 PM
djnoclue
Jun 9, 2003 01:11 PM
