Need help w/ my miller sync. 200
Hey guys, a while back I purchased a brand new miller sync. 200 and didn't get to try it out due to my busy schedule. At the time, I also didn't have the money to get the house wired. Anyway, I finally got the house wired and I decided to try out my welder. The machine turns on but for some reason i can't get an arc started. The work clamp is properly grounded and the torch and foot control are also properly connected. The torch just doesn't produce an arc when I press on the foot pedal. After I release the pedal, I do hear the postflow noise. I'm also using a 2% thoriated tungsten. I have the machine set to DC electrode negative and the process I selected is TIG. Do you guys have any ideas of why I can't get an arc started? Any possible things I should check? If it's a wiring issue, how can I check to see that the job was done right? Thanks guys. Your help is greatly appreciated.
sorry i can help you, i am in the same boat. i brought my syncrowave 200 almost a month ago and havent used it yet. waiting for my uncle to come back to wire up an outlet and i still need to buy a tank. ill keep an eye on this thread cuz i am intrested to know what wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SQ is the SQUAD »</TD></TR><TR><TD CLASS="quote">sorry i can help you, i am in the same boat. i brought my syncrowave 200 almost a month ago and havent used it yet. waiting for my uncle to come back to wire up an outlet and i still need to buy a tank. ill keep an eye on this thread cuz i am intrested to know what wrong</TD></TR></TABLE>
Cool, thanks anyway bro.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 »</TD></TR><TR><TD CLASS="quote">Does it only do it with a hifreq start? Or does it work with lift-arc?</TD></TR></TABLE>
I'm guessing so because from what I understand the machine is always on Hifreq start. I don't have a switch like some of the other welders to switch on and off of Hifreq. The only thing I can do is change the starting characteristics of the tig HF. Right now, I have it on DCEN Med. I apologize if I'm confusing you, but I'm just not sure how or when I can select lift arc. Thanks for your help man.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danielm3 »</TD></TR><TR><TD CLASS="quote">Mine would do that when the tip is dirty, if I touch it to the base matal it would start rigth up (sometimes leaving a hole
)</TD></TR></TABLE>
I tried what K24em2 said I should try and that happened twice. It made a huge spark and left a hole in the metal. I cleaned the material and the tungsten and got nothing. I tried tapping the tungsten on the work again and nothing happened. I guess it only happens sometimes. Well, thanks for the help guys. If i get this figured out, I'll post what the problem was.
)</TD></TR></TABLE>I tried what K24em2 said I should try and that happened twice. It made a huge spark and left a hole in the metal. I cleaned the material and the tungsten and got nothing. I tried tapping the tungsten on the work again and nothing happened. I guess it only happens sometimes. Well, thanks for the help guys. If i get this figured out, I'll post what the problem was.
this may be a silly suggestion, but you had mentioned your clamp was grounded. I dont know if it makes any difference. but on mine. i have the clamp as + and the torch hooked up to the - port.
its wiring had it happen to me on my 180 one time when i moved it from home to shop and didnt connect the wires properly. make sure the plug is wired properly and matching the outlet in your house
the cartel
Nov 21, 2004 01:05 PM
