Oil Filter
Old Jul 8, 2006 | 04:10 PM
ninety-five_DB's Avatar
Default Oil Filter
Does anyone have any tips on how to remove the oil filter from the engine block? I have tried hand-loosening and tried a filter wrench and i am still unable to loosen the filter.
Old Jul 8, 2006 | 04:51 PM
projectTeG's Avatar
id say the filter wrench is the best bet, if the filters not that old and bad id say put some cheap oil in the engine and start the engine to get the engine warm to try and break the seal.
Old Jul 8, 2006 | 07:13 PM
jared99's Avatar
Default Re: (projectTeG)
ok, i know this is gonna sound kinda tacky. I have the filter wrench that fits onto the end of a ratchet. I'd put an impact wrench or breaker bar on it and remove it that way. it's a tight fit under the IM but might work.
Old Jul 8, 2006 | 07:43 PM
integra3586's Avatar
Default Re: (jared99)
no!!!!!!!!! dont do that. just give it a little elbow grease
Dartanian's Avatar
Default Re: Oil Filter (ninety-five_DB)
Free way: Take a screwdriver, hammer it into the filter, and use the handle as leverage to loosen the oil filter. Make sure you wear goggles because oil will most likely end up all over you and your face.
Cheap, but not free way: Get a tool that looks like a handle with a metal circular strap connected to it. I use one of those and have never had a problem getting my oil filters off.
Old Jul 8, 2006 | 08:25 PM
k624ash's Avatar
Default Re: Oil Filter (Sleeper Style)
i used the screwdriver method, and i give it a
Old Jul 8, 2006 | 08:35 PM
GoCarInteg's Avatar
Default Re: Oil Filter (k624ash)
Another Free Way - Get a stronger person to try to take it off
Old Jul 8, 2006 | 09:19 PM
Default Re: Oil Filter (GoCarInteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoCarInteg &raquo;</TD></TR><TR><TD CLASS="quote">Another Free Way - Get a stronger person to try to take it off </TD></TR></TABLE>
what a quack
Old Jul 9, 2006 | 01:48 AM
teknoracing's Avatar
or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k624ash &raquo;</TD></TR><TR><TD CLASS="quote">i used the screwdriver method, and i give it a </TD></TR></TABLE>
OR if all else fails do both.
Old Jul 9, 2006 | 07:10 AM
projectTeG's Avatar
dont deform the filter with the screwdriver method...you wont beable to use the wrench any more, just use a extension on the rachet if you have to.
Old Jul 9, 2006 | 08:53 AM
IN VTEC's Avatar
Mac Tools OFH245 oil filter plier
or
Honda 07HAA-PJ70100 (I think this is the right one).
- Use with a flex head 3/8" drive ratchet
Old Jul 9, 2006 | 12:29 PM
projectTeG's Avatar
Default Re: Oil Filter (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Mac Tools OFH245 oil filter plier
or
- Use with a flex head 3/8" drive ratchet</TD></TR></TABLE>
best bets!
Old Jul 9, 2006 | 04:57 PM
IN VTEC's Avatar
Default Re: Oil Filter (projectTeG)
It's what I use at work and there hasn't been a Honda filter yet that I haven't been able to loosen between the two tools and some patience.
The hardest oil changes are the '02 to '06 CR-V's and '06 Civic Si's. TSX's and RSX's are kind of a pain as well.
Old Jul 10, 2006 | 07:31 PM
THE GAME IS THICK's Avatar
and thats the reason why he called me hahaha
Old Jul 10, 2006 | 07:34 PM
Uncle Willie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">It's what I use at work and there hasn't been a Honda filter yet that I haven't been able to loosen between the two tools and some patience.
The hardest oil changes are the '02 to '06 CR-V's and '06 Civic Si's. TSX's and RSX's are kind of a pain as well.</TD></TR></TABLE>
HAHA...LMFAO. IF you think those are hard, i would suggest doing some oil changes on pretty much ANY volkswagon or RX300/v6 highlander. I ******* HATE THOSE CARS. When i honda comes in all i can think of is relief. Hondas and MOST GM's are SO easy to do.
Old Jul 10, 2006 | 07:46 PM
LordAphotic's Avatar
the absolute best way to get that sucker off... is to get a leather belt... like the kind you wear around your stomach. and wrap it around but leave enough hanging cause your gona pull on it. make sure to have it on so it loosens when you pull on it not tightens.... also if you want to go even further spray some bolt loosener spray of any type where the filter meets the block. but make sure not to get any on the filter cause then the belt wont hold on as good.
it always works for me. it always works for all the mechanics i know. it always works!
you can put your body weight on to it....
make sure that when you put the new filter that you get a dab of oil and put it on the rubber seal so that it doesnt stick in the future. and when you change it again in the future your hand will be enough.
Old Jul 10, 2006 | 08:16 PM
JuggerNuts's Avatar
i just use those tennis racket wraps or those big band rubber bands the really tacky ones and wrap it around the filter or my fingers. grip seems to be the only problem in that tight space but it help me
Old Jul 10, 2006 | 09:00 PM
Default Re: Oil Filter (THE GAME IS THICK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THE GAME IS THICK &raquo;</TD></TR><TR><TD CLASS="quote">
and thats the reason why he called me hahaha</TD></TR></TABLE>
lol...well, i used that screwdriver trick and it worked...except for the mess it created...thank god for Shop Towels
ninety-five_DB
Jul 8, 2006 05:03 PM
Halo
Sep 26, 2002 11:53 AM
EKB18BPR3
11
Aug 18, 2002 11:53 PM
yellowbuffalo
Mar 16, 2002 05:54 PM
Type Goch
Jul 1, 2001 10:11 AM
