del sol air bag block off
Old Jul 8, 2006 | 03:25 PM
boostinh22
Guest
Posts: n/a
Default del sol air bag block off
does anyone make one of these? i've got a 97 del sol. would the block off tray for an ek fit?
Old Jul 8, 2006 | 05:59 PM
hondapwr's Avatar
Default Re: del sol air bag block off (boostinh22)
I have a 93 Del Sol and there is only an airbag in the steering wheel... Therefore, you should just disable the SRS system and replace the steering wheel.
Old Jul 8, 2006 | 06:20 PM
dohcVTECeg2's Avatar
Default Re: del sol air bag block off (hondapwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapwr &raquo;</TD></TR><TR><TD CLASS="quote">I have a 93 Del Sol and there is only an airbag in the steering wheel... Therefore, you should just disable the SRS system and replace the steering wheel.</TD></TR></TABLE>
no. 94-97 del sols had a passenger side airbag located in the dash. he wants to eliminate the pass. side airbag not the one in the steering wheel.
to the OP i would just suggest you get a 93 del sol dash because those are the only ones in the U.S. that dont have a pass. side airbag. either that or fabricate your own. i dont think the EK or DC block off trays would fit. i never test fitted so im not quite sure.
Old Jul 9, 2006 | 07:38 AM
boostinh22
Guest
Posts: n/a
Default Re: del sol air bag block off (dohcVTECeg2)
anyone know of a block off tray?
Old Jul 9, 2006 | 07:49 AM
like i said none exist. so one would have to be fabricated to fit
Old Jul 9, 2006 | 10:14 AM
Out of every
get a 93 dash
Eddie 70
Feb 21, 2011 09:01 AM
