del sol air bag block off
Re: del sol air bag block off (boostinh22)
I have a 93 Del Sol and there is only an airbag in the steering wheel... Therefore, you should just disable the SRS system and replace the steering wheel.
Re: del sol air bag block off (hondapwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapwr »</TD></TR><TR><TD CLASS="quote">I have a 93 Del Sol and there is only an airbag in the steering wheel... Therefore, you should just disable the SRS system and replace the steering wheel.</TD></TR></TABLE>
no. 94-97 del sols had a passenger side airbag located in the dash. he wants to eliminate the pass. side airbag not the one in the steering wheel.
to the OP i would just suggest you get a 93 del sol dash because those are the only ones in the U.S. that dont have a pass. side airbag. either that or fabricate your own. i dont think the EK or DC block off trays would fit. i never test fitted so im not quite sure.
