best syn oil and filter combo?
AMSOil is really good from what ive had experience. I used to run it in my GS-t.
Holds up really well under 18-20 lbs of boost. Now, performance on our NA or Turb'd motors, I dont know.
I personally use Mobil1 Pure synthetic 5-30.
7500 miles between oil changes!!!
And I only use a K&N oil filter.
alright that sounds good! those items are alot eaiser to get than what i listed. i would have to order it online then wait for the stuff to come in.
I use mobile one 5w20 with a mobil one oil filter. But truly you do not see a difference in oil until you get into redline or other oils like that. I know this becasue i work with oil every day. But syenthetic is better then non, thats not what i am saying.
yeah, i looked into it earlier and i'm definitely fine with the 10w30....the 10 compared to the 5 is definitely ok because 5w oil is usually used when the car is going to see sub zero temperatures, which i won't see any time of the year in North Carolina...the summertime heat is also going to offset the thickness of the 30 weight a little...and oil also thins out as it's used...
so all in all. i feel safer with the 10w30
