scratchs front main seal mating surface
ok heres the story:
i found out my gsr oil pump had a bad pressure valve so i replaced it with a ITR pump brand new from acura. after about 2 days of driving i noticed oil on the ground, so i figured it was my oil pan gasket, but after a few inspections i noticed it was coming from the crank pulley area, so i decided to pop the pump off. once the pump was off i immediately notice the that the seal was deformed and the was a noticeable polished mark from the seals spring rubbing the surface. the mark is hard to feel on the tip of the finger nail.
now my question is will i beable to just install a new seal or will i need a new crank?
I would wipe is down, and try putting a new seal on
if it still does the same thing, I would take some very fine sand paper and sand lightly to give is a slight rough surface to seal to and get rid of the polished mark
I would try everything before replacing the crank
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Mang »</TD></TR><TR><TD CLASS="quote">I would wipe is down, and try putting a new seal on
im gonna try everything..lol, this would suck. the good thing is acura replaced the pump and a new o-ring for free
</TD></TR></TABLE>im gonna try everything..lol, this would suck. the good thing is acura replaced the pump and a new o-ring for free
Chargerhemi06
Dec 4, 2014 05:43 PM
