intake manifold question
Old Jul 8, 2006 | 11:55 AM
dc2guy's Avatar
Default intake manifold question
so i got a skunk 2 pro series itm and i put it on and every thing is hooked up right and i started it up and it idles around 3500rpm,wtf is wrong?
Old Jul 8, 2006 | 12:02 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: intake manifold question (dc2guy)
You most likely have a vacuum leak.
Old Jul 8, 2006 | 12:23 PM
dc2guy's Avatar
i checked every line going to the manifold
Old Jul 8, 2006 | 12:38 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (dc2guy)
Place your hand over the throttle body inlet and see if it still idles. You must be getting air from somewhere.
Old Jul 8, 2006 | 12:56 PM
DC2 Mang's Avatar
Default Re: (Dogginator)
did you use a new Intake manifold gasket when you put the manifold on?
sounds like you missed a hose or something, or didnt screw a sensor on tight enough
check your iacv, fitv, throttle bods, and temp sensor
Old Jul 8, 2006 | 01:24 PM
dc2guy's Avatar
i put my hand over it and it still idles at 2200rpm,yes i used a new gasket,i have checked every bolt and hose
Old Jul 8, 2006 | 03:37 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2guy &raquo;</TD></TR><TR><TD CLASS="quote">i put my hand over it and it still idles at 2200rpm,yes i used a new gasket,i have checked every bolt and hose</TD></TR></TABLE>
You definitely have a vacuum leak. You just need to find it now. Perhaps you can hear it leaking.
Old Jul 8, 2006 | 04:09 PM
lsvtek's Avatar
use carb cleaner on ur iacv? thats what people told me and it fixed my idle
Old Jul 8, 2006 | 04:17 PM
Robstunner4's Avatar
Default Re: (4drlsintegra)
did u clean the port area of all the old gasket. it has to be 100% perfect or it will not seal right at all. even a scratch can make a small leak
Old Jul 8, 2006 | 04:27 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drlsintegra &raquo;</TD></TR><TR><TD CLASS="quote">use carb cleaner on ur iacv? thats what people told me and it fixed my idle</TD></TR></TABLE>
It is not his IACV. He eliminated that possibility when he sealed the throttle body with his hand.
Old Jul 8, 2006 | 05:27 PM
dc2guy's Avatar
Default Re: (Robstunner4)
it may have had a little of the old gaket left on, i dont remeber, thats probely what it is
Old Jul 8, 2006 | 06:08 PM
yeah, anything that will make it not flush will mess with it.
Old Jul 8, 2006 | 09:52 PM
DC2TEGGA-GSR's Avatar
that or youve got a vacuum line running to the wrong place (thats what i did) and had the same idle results
Old Jul 8, 2006 | 11:23 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2guy &raquo;</TD></TR><TR><TD CLASS="quote">it may have had a little of the old gaket left on, i dont remeber, thats probely what it is</TD></TR></TABLE>
That is the same problem I had when I didn't scrape off the old gasket that had crusted itself to the head and manifold. Scrape it off the best you can and that should fix the leak. The air is coming in between the head and manifold.
A simple vacuum leak will only give you a bouncy idle about 750 rpms higher than spec.
Old Jul 9, 2006 | 12:05 AM
DC2 Mang's Avatar
Default Re: (Sleeper Style)
I hear a trick to find vacuum leaks is to spray brake or carb cleaner on the suspected area and start the car, if it sucks the cleaner in you found your leak
hectic57
Mar 18, 2008 07:16 PM
94hondacivicvtec
28
Mar 28, 2007 06:08 PM
b18danger
Sep 18, 2005 09:31 AM
C4wrx
Apr 3, 2002 12:46 AM
C4wrx
Apr 2, 2002 03:52 AM
