Pin location for obd2b 2-wire iacv ground?
What is the pin location for the 2-wire iacv ground wire on a 5-spd obd2b harness? I know the power wire is B23, but I don't know which is the ground wire pin location. Thanks
^I've read that a dozen times before and can't find it. There are a dozen yellow/black wires at the ecu for grounds. I need to know which one it is without having to rip each one of them out to see.
85mm LS VTEC
Apr 11, 2005 06:46 PM
