Help! h22 cuts out at high revs
Old Jul 8, 2006 | 10:43 AM
JasonST's Avatar
Default Help! h22 cuts out at high revs
I posted this here b4 with no success so this time I'm posting this with a link to a movie of it. The problem is anywhere from 6300-6800 my engine cuts out, even with my foot ON the gas pedal the whole time, and it kicks back, but completly recovers from it. Vtec kicks in loud and strong, no cels. It's a teg with an h22, using a p13, oil level is good, all 3 grounds are good, Vtec solenoid tests good, replaced spark plugs, ignition coil. O and this might help, when it cuts out, and I try to rev it high in the next gear, Vtec won't engage! But then I shift and it'l engage fine in the next gear, it's like it has a cool down or something. But everytime it cuts out it won't engage in the next gear but it will the gear after that.
Any help would be great!
http://www.we-todd-did-racing....5NTQx
Old Jul 8, 2006 | 05:44 PM
JasonST's Avatar
Default Re: Help! h22 cuts out at high revs (JasonST)
Bump! Cmon, plz somone's gotta have an answer, or some help.
Old Jul 8, 2006 | 06:08 PM
asdfsad's Avatar
i have no idea whats wrong with it, but the video wont load.
Old Jul 8, 2006 | 06:58 PM
PrettyLude's Avatar
i had the same exact problem man, i found out it was the dizzy going out
Old Jul 8, 2006 | 09:10 PM
RemerLex11's Avatar
make another link man, it doesnt work
edit: p13- i dont know much about this, but you might be in limp mode
Modified by Matt5745767 at 10:24 PM 7/8/2006
Old Jul 8, 2006 | 10:31 PM
RJonathan's Avatar
had the same problem once too. I just swapped out the dizzy. but on mine TDC sensor inside the dizzy broke so it caused me to be in limp mode
Old Jul 9, 2006 | 09:27 AM
JasonST's Avatar
Default Re: Help! h22 cuts out at high revs (RJonathan)
K uploaded the video clip to another site, this should work.
http://videos.streetfire.net/v...a.htm
Old Jul 11, 2006 | 09:56 PM
brucesi's Avatar
ok what ecu are u using
Old Jul 11, 2006 | 09:58 PM
brucesi's Avatar
Default Re: Help! h22 cuts out at high revs (brucesi)
and when u got the engine was the engine auto and u tranform to manual is that right
JasonST's Avatar
already said in first post, stock p13
Old Jul 11, 2006 | 10:35 PM
brucesi's Avatar
what im saying are u using the ECU that came with the car or H22 that came with the engine and was the engine auto or u had to do swap to make it manual
Old Jul 11, 2006 | 10:46 PM
98vtec's Avatar
moderator emeritus
sounds to me like its got a lowered rev limiter due to a check engine light. Are you running a knock sensor?
Old Jul 12, 2006 | 08:09 AM
JasonST's Avatar
Default Re: Help! h22 cuts out at high revs (98vtec)
Yeah a p13 is the stock ecu that comes with the h22, it's a manual and I switched my car to a manual too. And EGR doesn't lower the revlimiter or make it run in limp mode, it's not a rev limiter, if u watch the movie, it won't bounce like a rev limiter, it will hit the rpm then drop and cut out, and if u watch the video ther's no cel. Thx for the help though.
littledan
Nov 30, 2018 09:22 PM
nathan444111
Jun 9, 2012 10:29 AM
JasonST
Jul 9, 2006 09:33 AM
