Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
problem with rear shock bolts??
Old Jul 8, 2006 | 09:58 AM
gitrdone's Avatar
Default problem with rear shock bolts??
i got this problem with torqueing my rear shock bolts (the middle one thats on the top) i try to tighten them but the rubber bushing under it just twist with the bolt and i dont want to tear the rubber bushing.. anyone have this kind of problem???
Old Jul 8, 2006 | 10:05 AM
fventura03's Avatar
there is supposed to be a metal washer between the rubber bushing and the bolt. you use an allen wrench and a monkey wrench to tighten that top bolt.
Old Jul 8, 2006 | 12:29 PM
gitrdone's Avatar
Default Re: problem with rear shock bolts?? (catch_me_if_u_can)
i did but even though the washer is there the bushing still turns, plus you cant torque the bolt with an allen wrench and a monkey wrench, you have to use a ratchet. i tried torqueing it to 43lbs but nope cant do it. do i have to torque to 43lbs or could i just leave it hand tightend?
Old Jul 9, 2006 | 03:54 AM
Newborn_'s Avatar
Grace Under Pressure
I wouldn't leave it hand tightened. I'd try everything you can and then pop to a car garage and get them to do it for you if you're still struggling.
Tightening torques aren't a "suggestion".
qazaq
Jan 19, 2007 10:11 PM
usmarinedelta
Dec 27, 2006 08:52 PM
EGhatch33
Suspension & Brakes
24
Jan 2, 2006 10:01 AM
99_dc2
Suspension & Brakes
Sep 3, 2005 08:12 PM
Chronicsinners
Feb 20, 2003 12:20 PM
