I think my power wire is way to big?
Old Jul 8, 2006 | 09:21 AM
hybrid1990crx's Avatar
Default I think my power wire is way to big?
Ok so I'm really not to big on stereos, but I had this amp and sub laying around so I decided to throw it in. Well I didnt have a power wire so I borrowed one from a friend but its huge, like 0 guage im assuming its like the size of my pinky finger. I've been trying to find a 2 prong connection to connect the power wire to my amp, but no luck.
Should I just get a smaller power wire? Its a 600 watt amp if that matter?
Old Jul 8, 2006 | 09:49 AM
suspendedHatch's Avatar
Default Re: I think my power wire is way to big? (hybrid1990crx)
You could get the same power from an 8 gauge or at the most, a 4 gauge wire.
Old Jul 9, 2006 | 07:17 AM
dohcVTECeg2's Avatar
Default Re: I think my power wire is way to big? (suspendedHatch)
i would go with a 4 guage cable if your running more than 8 ft. or longer
http://www.the12volt.com/info/recwirsz.asp
Old Jul 9, 2006 | 10:59 AM
bpr0422's Avatar
you shouldn't be running the wire directly from the batt to the amp...
it should go...
Batt -> 8-12in -> fuse (ANL) -> 0/4 wire -> fused distribution block -> 4/8 guage -> amp
that way you can still use the 0/2 gauge wire you got from your friend, because at the distribution block, the wire is converted into smaller guage wiring
Old Jul 11, 2006 | 03:43 AM
slowSOHCvtec's Avatar
Default Re: I think my power wire is way to big? (bpr0422)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote">you shouldn't be running the wire directly from the batt to the amp...
it should go...
Batt -&gt; 8-12in -&gt; fuse (ANL) -&gt; 0/4 wire -&gt; fused distribution block -&gt; 4/8 guage -&gt; amp
that way you can still use the 0/2 gauge wire you got from your friend, because at the distribution block, the wire is converted into smaller guage wiring</TD></TR></TABLE>
this way if you ever decide to upgrade amps you still have the 0awg wire available. or even if you get a second amp for speakers, another sub, etc, get a distribution block and make sure its fused or else boom boom no more electronics for that honda!
Old Jul 13, 2006 | 09:32 AM
LudemanDan's Avatar
There is nothing wrong with running too big a wire, only too small. Yes, it's more work and more small parts to convert the sizing with distribution blocks and stuff, but that way you don't have to buy more unnecessary wire that will have more resistance than your nice-*** scrap 0g.
Old Jul 13, 2006 | 01:17 PM
mhart's Avatar
i would find something to connect your wire to the amp, you guys are going fuse crazy, i dont use fuses and don't like them.
Old Jul 13, 2006 | 02:37 PM
rcurley55's Avatar
New User
Default Re: (mhart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mhart &raquo;</TD></TR><TR><TD CLASS="quote">i would find something to connect your wire to the amp, you guys are going fuse crazy, i dont use fuses and don't like them.</TD></TR></TABLE>
well, it's nice to know you like burning down your car...
Old Jul 13, 2006 | 03:12 PM
fcm's Avatar
fcm
Old Fart
Default Re: (mhart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mhart &raquo;</TD></TR><TR><TD CLASS="quote">i would find something to connect your wire to the amp, you guys are going fuse crazy, i dont use fuses and don't like them.</TD></TR></TABLE>Brahahahahahahahahah! you no0bs crack me up.
highbrid1990crx you need something like this... http://www.scosche.com/efx.asp...P04CI 94
Old Jul 13, 2006 | 04:59 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (mhart)
Any body that reads this, Steer clear of his advice,lol. I bet you didn't even use a groment to run the power wire thru the firewall. Or went thru the factory one. Your battery is a waiting time bomb. I feel sorry for your audio equipment.
Old Jul 13, 2006 | 06:05 PM
Default Re: (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">Any body that reads this, Steer clear of his advice,lol. I bet you didn't even use a groment to run the power wire thru the firewall. Or went thru the factory one. Your battery is a waiting time bomb. I feel sorry for your audio equipment. </TD></TR></TABLE>
yeah this guy is a real jackass...once his rubber coating wears off his undersized power wire and it shorts...without a fuse bye bye electronics, and bye bye battery, alternator, voltage regulator. basically any electronic component in the car..
mhart, let me know when the fireworks show starts!
Old Jul 13, 2006 | 07:06 PM
SloCrxDx91's Avatar
Default Re: (mhart)
wow.........thats a good idea
Old Jul 13, 2006 | 07:07 PM
SloCrxDx91's Avatar
But to answer your question I would run 8 gauge because that is probably all that will fit in the amp.
Old Jul 14, 2006 | 06:16 AM
fcm's Avatar
fcm
Old Fart
Default Re: (slowSOHCvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowSOHCvtec &raquo;</TD></TR><TR><TD CLASS="quote">
mhart, let me know when the fireworks show starts! </TD></TR></TABLE>Electronics? He would be lucky if all that happens is the batt. explodes, more then likly the car will burn to the ground. 94
Old Jul 14, 2006 | 06:46 AM
LudemanDan's Avatar
Default Re: I think my power wire is way to big? (SloCrxDx91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloCrxDx91 &raquo;</TD></TR><TR><TD CLASS="quote">But to answer your question I would run 8 gauge because that is probably all that will fit in the amp. </TD></TR></TABLE>
You can still run the 4g all the way through and then step down to 8g right before the amp.
Or you could just run 8g. Don't know what we're debating anymore.
imadigitalgod
Audio / Security / Video
Jan 5, 2009 08:13 AM
MilanoCivic97
Apr 4, 2007 11:22 AM
Gman8941
11
Oct 10, 2004 08:13 AM
mattduskater
May 12, 2003 04:49 PM
ITRVietBoi
May 30, 2002 09:27 PM
