H22A injectors what do i need???
Old Jul 7, 2006 | 11:22 PM
prelude72569858's Avatar
Default H22A injectors what do i need???
ok im doing a h22a swap into my 92, i dont have injectors and am looking to buy new ones. but im the type that hates to buy a stock part when you can get a better one for a couple bucks more. so im looking into bigger better injectors.. any suggestions?? have 8 basic bolt ons, what else to i have to change to run slightly bigger injectors? and if anyone knows pros and cons on peak+hold and saturated??
Old Jul 8, 2006 | 12:51 AM
MLBZ521's Avatar
Default Re: H22A injectors what do i need??? (prelude72569858)
Um.. If you staying OBD1 then you NEED Peak & Hold Injectors.. If you're staying N/A with only some bolts on's then Stock Injectors will work fine.. They're 345cc for the H22A and H22A1 OBD1 Motors.
Saturated are for OBD2 ECU's and are smaller cc's, stock of course.
From the Factory the Injectors cost $116 a piece so it's over $450 for all four..
You can find them used for cheaper.. Some people practically give them away for the prices they sell them for..
*I have a set also if you would like them.. Just let me know..
Old Jul 8, 2006 | 06:06 AM
98vtec's Avatar
moderator emeritus
Default Re: H22A injectors what do i need??? (MLBZ521)
the stock OBDII injectors are good to ~200whp
stock OBDI 345's are good to a little more than 200whp
until you are making beyond 200whp, you dont need to worry about changing injectors.
Old Jul 8, 2006 | 08:20 AM
MLBZ521's Avatar
Default Re: H22A injectors what do i need??? (98vtec)
^^Yeah.. And you'll need a stronger, I guess that's how you would word it, fuel pump. Like a Walbro 255lp..
And an Aftermarket Fuel Pressure Regulator would help.
Aftermarket Fuel Rail of Course..
Might be others, but that's good to start with..
Old Jul 8, 2006 | 11:10 AM
ilikehonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLBZ521 &raquo;</TD></TR><TR><TD CLASS="quote">^^Yeah.. And you'll need a stronger, I guess that's how you would word it, fuel pump. Like a Walbro 255lp..
Might be others, but that's good to start with..</TD></TR></TABLE>
you lie sir. not even 350hp motors need a bigger fuel pump or fuel pressure regulator and aftermarket fuel rail is just stupid unless you are makeing more than 400. that is a load of ****!!
talk to a tuner they know their ****. you cannot just put bigger injectors in. lets say for example your computer has your 345 injectors running at 65% of their capacity and that is 1 gallon per hour (not even close to true just an example) and you put in 500cc injectors. your computer will have them run at 65% and at 65% of their capacity that is the same thing as 3 gallons per hour. see the problem here??.
so if you want bigger injectors you will need something to tune them with. i do not suggest the vafc or safc the are only band aids. get something like a stand alone. so just keep it simple and leave it stock.
if you have simple bolt ons then just get the stock 345cc (peak and hold not saturated)injectors. you can find them cheap. check out homemadeturbo.com they have them all the time.
Old Jul 8, 2006 | 11:38 AM
bb_one's Avatar
Default Re: H22A injectors what do i need??? (ilikehonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikehonda &raquo;</TD></TR><TR><TD CLASS="quote">
if you have simple bolt ons then just get the stock 345cc (peak and hold not saturated)injectors. you can find them cheap. check out homemadeturbo.com they have them all the time.</TD></TR></TABLE>
That's as straight foward as you can put it
Old Jul 8, 2006 | 11:47 AM
MLBZ521's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikehonda &raquo;</TD></TR><TR><TD CLASS="quote">you lie sir. not even 350hp motors need a bigger fuel pump or fuel pressure regulator and aftermarket fuel rail is just stupid unless you are makeing more than 400. that is a load of ****!!</TD></TR></TABLE>
lol, Sorry.. I didn't mean "Need" those items.. Just meant that they could help.. And I wasn't trying to say they'd be needed for just simple bolts on's and such.. I meant after that, after more than just bolt on's...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikehonda &raquo;</TD></TR><TR><TD CLASS="quote">talk to a tuner they know their ****. you cannot just put bigger injectors in. lets say for example your computer has your 345 injectors running at 65% of their capacity and that is 1 gallon per hour (not even close to true just an example) and you put in 500cc injectors. your computer will have them run at 65% and at 65% of their capacity that is the same thing as 3 gallons per hour. see the problem here??.
^^Yes yes, I agree with that completely.. I didn't ever say he'd need bigger injectors.. I know the Stock Injectors are enough for most applications.. I don't think I stated that "bigger" injectors were needed..
Sorry for the confusion..
Old Jul 8, 2006 | 03:06 PM
ilikehonda's Avatar
Old Jul 8, 2006 | 08:22 PM
Eddiebx's Avatar
anyone ever flow test a prelude pump? i flow tested a stock 5th gen accord pump and shes only good to about 250whp tops. i wonder if the lude ones have a higher capacity.
Old Jul 9, 2006 | 12:01 AM
ilikehonda's Avatar
Default Re: (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">anyone ever flow test a prelude pump? i flow tested a stock 5th gen accord pump and shes only good to about 250whp tops. i wonder if the lude ones have a higher capacity.</TD></TR></TABLE>
you lie!!! or just have no idea what you are talking about. there are numerous cars on here making over 300whp with the stock fuel system. i will soon be one of those
Old Jul 9, 2006 | 11:12 AM
98vtec's Avatar
moderator emeritus
Default Re: (ilikehonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikehonda &raquo;</TD></TR><TR><TD CLASS="quote">you lie!!! or just have no idea what you are talking about. there are numerous cars on here making over 300whp with the stock fuel system. i will soon be one of those</TD></TR></TABLE>
he didnt say the prelude one is only good to 250whp now did he?
he said he flow tested an accord pump.
and if you read through alot of his posts you will see that eddie knows what he is talking about.
Old Jul 9, 2006 | 12:52 PM
ilikehonda's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">
and if you read through alot of his posts you will see that eddie knows what he is talking about. </TD></TR></TABLE>
i dont have a prelude either and i also know other accords using the STOCK FUEL SYSTEM and making over 300 whp. so obviously his calculation is wrong. i was exaggerating the knowing nothing. he could be a genius i have no idea but i know of plenty of accords making more than 250whp with the stock pump
Old Jul 9, 2006 | 12:57 PM
98vtec's Avatar
moderator emeritus
that doesnt mean they arent going passed the safe limit of the pump . You dont want to run fuel devices to their max, same goes for pretty much everything else. Just like injectors; your not supposed to run an injector beyond 85% duty cycle.
Old Jul 9, 2006 | 01:09 PM
Eddiebx's Avatar
well, i meant safely. sure you can push it to the max, and it will probably handle 300whp, but do you really think a pump is going to last very long running it at 100%, i wouldn't think it will be all that great for it.
If you care, here are the flow charts i got from RC engineering, and i plotted it on a graph.
http://www.hondasociety.com/bo...92319
it's not like i am pulling these numbers out my ***, so calm the expletive down. just cuz you saw your friend's cousin's sister's massage therapist make 300whp on an accord pump, doesn't exactly mean it's safe.
Old Jul 9, 2006 | 01:29 PM
98vtec's Avatar
moderator emeritus
no kidding.
Old Jul 9, 2006 | 06:43 PM
ilikehonda's Avatar
good find however my sisters, cousins, hairdressers, boyfriends, mothers, sisters car has been running the stock pump for 3 years now making 325whp. and did i say anything about it lasting? no however it can and will work.
Old Jul 9, 2006 | 08:32 PM
hu's Avatar
hu
Did they have aftermarket injectors? Maybe they just had higher pressure injectors or an adjustable fpr. Although higher pressure is no replacement for volume. Just my .02.
Old Jul 10, 2006 | 04:44 AM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikehonda &raquo;</TD></TR><TR><TD CLASS="quote">good find however my sisters, cousins, hairdressers, boyfriends, mothers, sisters car has been running the stock pump for 3 years now making 325whp. and did i say anything about it lasting? no however it can and will work.</TD></TR></TABLE>
seriously dood, do and think what you wish. if you like to half *** everything, that's fine, it's not my car, and not my wallet.
I already showed you the flow numbers of a stock accord pump, if you choose to ignore it, good for you.
Old Jul 10, 2006 | 05:20 AM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
wow this thread has turned into "my ***** bigger than yours" crap..shame shame shame....
Old Jul 10, 2006 | 12:43 PM
ilikehonda's Avatar
i wouldnt call it half assing. just not spending unneccessary money. it will support the hp. i see what your flow chart says and you are right it is pushing it however it will work and if you know what you are doing it will last a long time
Old Jul 10, 2006 | 10:49 PM
v4lu3s's Avatar
RTFM
RC Engineering did not get to where it is by spreading bad information and lying. If they say that they would not recommend usign a stock pump to go beyond 250 whp I would jsut go buy a Walbro pump.
Its a lto easier and cheaper to buy a $99 pump and put it in then it is to blow your engine up.
Old Jul 10, 2006 | 11:06 PM
hu's Avatar
hu
Why in the world would Honda make a stock fuel pump that would support 300whp? Wouldn't happen.
Old Jul 10, 2006 | 11:21 PM
MLBZ521's Avatar
Default Re: (hu)
^^I couldn't be positive about it... But I wouldn't say "Honda" actually made it.. It was probably made by another manufacture and Honda uses it in their cars..
So it would be to the Specs that the actual manufacture made it..
But as always, I could be wrong..
Old Jul 11, 2006 | 12:21 AM
ilikehonda's Avatar
Default Re: (hu)
why in the world would they make axles, trannys, internals, sleeves etc to withstand 300 hp? why would they put injectors that will support 250-270? no one knows but **** happens
Old Jul 11, 2006 | 03:11 AM
98vtec's Avatar
moderator emeritus
250 -270 in what?
sure hope your not talking about an h22
