getting a atts tranny to work on a h22a
Old Jul 7, 2006 | 09:12 PM
JDM_COUPE's Avatar
Default getting a atts tranny to work on a h22a
is there a way to get the atts tranny to work on a h22a, by htat i mean can you take of the bell gousing and put the non atts bellhousing on and change out the diff. has anybody ever tried this?
Old Jul 8, 2006 | 12:39 AM
JDM_COUPE's Avatar
Default Re: getting a atts tranny to work on a h22a (JDM_COUPE)
bump
Old Jul 8, 2006 | 12:54 AM
MLBZ521's Avatar
I'm not sure.. But I don't think so??
I know the ATTS unit is bolted to the back of the block and I dunno if the previous (Closed deck H22A & A1's) blocks have the holes for the ATTS to bolt on..
I could of course be wrong... Just trying to help some..
Old Jul 8, 2006 | 01:48 AM
JDM_COUPE's Avatar
Default Re: getting a atts tranny to work on a h22a (MLBZ521)
thank you for some input but the non atts equiped blocks dont have the hole for the atts on it. the question was probably wordded confusing. i ment convert a atts tranny by using a non atts bellhousinh and diff to work on a non atts motor. basically getting rid of the atts all together by using non atts parts
Old Jul 8, 2006 | 04:18 AM
AnthonyG2003
Guest
Posts: n/a
wouldnt it be easier to just buy a non atts tranny and slap it on? thats just my 2 cents.
Old Jul 8, 2006 | 04:19 AM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
why??
Old Jul 8, 2006 | 04:28 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: getting a atts tranny to work on a h22a (I got the CD5 Jeebies!)
why to me or why to him? lol
Old Jul 8, 2006 | 05:13 AM
Default Re: getting a atts tranny to work on a h22a (AnthonyG2003)
to the OP I am interested in his reasnonig for wanting to do this????
Old Jul 8, 2006 | 12:45 PM
JDM_COUPE's Avatar
why not? if you have a h22 tranny with grinding gears and have a atts tranny with good gears could you put it together and make it work?
Old Jul 8, 2006 | 03:29 PM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_COUPE &raquo;</TD></TR><TR><TD CLASS="quote">is there a way to get the atts tranny to work on a h22a, by htat i mean can you take of the bell gousing and put the non atts bellhousing on and change out the diff. has anybody ever tried this?</TD></TR></TABLE>
The bell housings are the same.
Non-atts blocks place the oil filter where atts related parts are supposed to bolt to.
You could get a type S engine, they came with atts.
Old Jul 8, 2006 | 03:37 PM
JDM_COUPE's Avatar
Default Re: getting a atts tranny to work on a h22a (sharkcohen)
i think the bell housing on atts has a bigger hole where the atts would go. i know all about the atts blockand and how they are different from non atts blocks. i wondering on the tranny. i would assume the diff is also different becasue of the attts.
i have a non atts block and a non atts tranny that grinds every gear but a atts tranny that is mint. im trying to get the atts tranny to work on a non atts block by using parts off of the non atts tranny. i guess ill have to spend the money and try and see what happens
Old Jul 9, 2006 | 12:17 PM
JDM_COUPE's Avatar
anybody want to share the knowledge?
Old Jul 9, 2006 | 04:47 PM
snobordboy's Avatar
Moderator
sounds to me like you just want to put the internals from your base tranny into the sh tranny housing, or just replace the synchros on the sh tranny.
Old Jul 10, 2006 | 12:14 AM
JDM_COUPE's Avatar
Default Re: getting a atts tranny to work on a h22a (snobordboi)
the other way around. i want to put everything from a sh tranny into a bas tranny. but it is possible? are the gears designed different?
Old Jul 11, 2006 | 12:07 AM
JDM_COUPE's Avatar
last bump before i attempt to do it
casting.shadow
Transmission & Drivetrain
Nov 15, 2009 05:41 PM
pcguy760
Apr 16, 2007 10:21 PM
H-powerd
Jan 28, 2007 09:13 PM
Heffer805
May 23, 2005 12:52 PM
