HELP! Oil fouled spark plugs...
Old Jul 7, 2006 | 06:55 PM
johnnyqsack's Avatar
Default HELP! Oil fouled spark plugs...
So I checked my spark plugs to see if they needed replacement, and I found 2 were corroded with oil. I took it to my honda dealer, they simply said it was the seals and fixed the 2 for $60. However, the oil is still there. What else could it be? And most importantly, will this hurt my engine?
Thanks guys.
Old Jul 7, 2006 | 07:17 PM
BLKFLSH's Avatar
Default Re: HELP! Oil fouled spark plugs... (johnnyqsack)
First of all: Accord? Model? Year? Engine? Where was the oil? On the top of the plug, or below the threads? (electrode part)
Old Jul 7, 2006 | 07:50 PM
Default Re: HELP! Oil fouled spark plugs... (BLKFLSH)
97 accord lx V4.... anyway the oil is in.... well the hole, or when you open up the plug, it is filled with oil. If that makes better sense. So on top of the spark plug...
Modified by johnnyqsack at 11:20 PM 7/7/2006
Old Jul 7, 2006 | 08:53 PM
Cerberus2k7's Avatar
They might have only replaced the upper seals and not the lower ones below the rocker arms. Check out http://www.cb7tuner.com/vbb/sh...seals so you can get an idea of what i'm talking about.
Old Jul 7, 2006 | 10:15 PM
knucklehead11's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnnyqsack &raquo;</TD></TR><TR><TD CLASS="quote">97 accord lx V4.... anyway the oil is in.... well the hole, or when you open up the plug, it is filled with oil. If that makes better sense. So on top of the spark plug...
Modified by johnnyqsack at 9:27 PM 7/7/2006</TD></TR></TABLE>
Sounds like the cam tower o-rings as my dealer called them. And btw, you have an I4, not a V4. I personally don't know of any cars in regular production that ever had a V4, much less Honda doesn't even make 'em to my knowledge. The only V4 I know of myself is the engine used in the 1962 Mustang I concept from Ford. But I figured I'd just remind ya.
pwrofdrm
Mar 29, 2023 06:50 AM
CRZ1
Apr 26, 2009 08:59 PM
St3v3
Dec 27, 2004 04:01 PM
crxaddikt
Aug 20, 2003 02:25 PM
D21X
Mar 25, 2003 12:44 PM
