An alternative to the A pillar gauge mounting
Well I've never been a big fan of gAy pillar gauges so i decided to make my mounting location, unemployment caused this as some can remember
Due to the heat of the south melting the tape and Autoworks EXtreme generosity I Had this, so know i had to put my guage(s0 some were else
this is not the finneshed product just most of the shaping is done, but its turning out pretty well so far.
I decide to uses the vent b/c it is in plain sight, Unlike the first one and I dont have a/c anymore.
BTW any one have a dc2 shift boot they would like to give me? or at least just the metal frame at the bottom?
i thought about that too but i didnt want to *** up my dash with holes for the gauge wireing. with this i can use the hole for the clock wiring
Modified by Got_soy at 2:03 PM 7/8/2006
Im not quite sure where your gonna place em, but I also have or guess should say, had my gauges where CRX rocks has his. The only problem with this is that I had EGT mounted the farthest over and let me tell you its hard as all get out to to read that thing being all of 2 1/16in. Next setup I do will have 2 5/8 because I dont want to have to try and really see what the gauge is reading, I want to glance and know exactly what its reading. That was also a problem with the boost gauge as well. It wasnt bad when I was running lower boost like 7psi but when I started running 17-18psi the gears go by A LOT quicker and you have a lot less time to look at your gauges.
Post up more pics as you get farther along.
Blaze
Post up more pics as you get farther along.Blaze
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy »</TD></TR><TR><TD CLASS="quote">Due to the heat of the south melting the tape and Autoworks EXtreme generosity I Had this...
Console looks good in there painted
Did that center piece ever get to you??
</TD></TR></TABLE>Console looks good in there painted
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy »</TD></TR><TR><TD CLASS="quote">yep second pic, its in</TD></TR></TABLE>
I meant the little oval piece I sent out afterwords that goes around the shiftboot area.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy »</TD></TR><TR><TD CLASS="quote">dash stays unmolested the vent gets raped but dash is still solid</TD></TR></TABLE>
I need the heat from that vent in the winter time
