Mini-Me Head bolt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy »</TD></TR><TR><TD CLASS="quote">Know the torque on a rocker arm assembly bolt offhand?</TD></TR></TABLE>
16ft-lbs for the inner ones (12mm bolts?)
9ft-lbs for the outer ones (10mm bolts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy »</TD></TR><TR><TD CLASS="quote">All mine are 12mm, I spose this is an obd1 thing perhaps. Or perhapsa nonvtec thing, I didn't think it was so little though, so thank you.</TD></TR></TABLE>
I got the specs from my factory manual for a Del Sol, the engine I looked at was a D15B7...figured the torque specs should be the same as any other non-vtec D-series motor from 88-95.
Cashieboi
Oct 9, 2006 08:17 PM
