GSR fab. plenum
Old Jul 7, 2006 | 03:26 PM
monster007's Avatar
Default GSR fab. plenum
Made this for a 2.1L with GSR head. Doing some testing but a gain of 20whp was seen went from 205whp to 225whp. Not the best looking intake but needed something quick.
Old Jul 7, 2006 | 03:47 PM
HamiltonRex's Avatar
Default Re: GSR fab. plenum (monster007)
brampton eh.. Local,
Nice work.
Old Jul 8, 2006 | 07:23 AM
hootiehoo's Avatar
whoa man!
did you like raid a scrap bin?
Old Jul 8, 2006 | 08:09 AM
FknBadFkr's Avatar
Default Re: GSR fab. plenum (hootiehoo)
thats deff cool. Good job and anypower is good power regardless of how it may look........Hal
Old Jul 8, 2006 | 12:35 PM
.RTErnie's Avatar
Default Re: GSR fab. plenum (FknBadFkr)
good power function over form anyday!
Old Jul 8, 2006 | 06:26 PM
1 bad rex's Avatar
yo you got to blend all those welds on the inside , it looks like you welded them through the inside and out side. or it had a supper penetration, im a welder at orlando metal fabrication here in orlando and did many plenums and manifolds in puerto rico and i know what a blended inside weld could do in terms of flow and power.sow try to blend it flush on the inside and youll see better results.... good luck.
Old Jul 8, 2006 | 08:14 PM
monster007's Avatar
Default Re: GSR fab. plenum (lares a gasolina)
these are the before pixs, it is all blended.
Old Jul 8, 2006 | 08:17 PM
Dude.. I seen your MR2 at CSCS at cayuga a month or so back.. You broke an axle first pass..
Sick car !
Old Jul 8, 2006 | 10:04 PM
weiRtech's Avatar
OG Fabricator
i don't know if i'd say quick, that looks like a lot of welding to me! nice gains though.
Old Jul 8, 2006 | 10:21 PM
SL0WEGG's Avatar
Default Re: (weiRtech)
20hp? **** i dont give a expletive what it looks like!
Old Jul 10, 2006 | 05:57 AM
monster007's Avatar
Default Re: (boostedej1)
"Dude.. I seen your MR2 at CSCS at cayuga a month or so back.. You broke an axle first pass..
Sick car !"
Now I am making a hub for it.
Modified by monster007 at 3:02 PM 7/14/2006
Old Jul 10, 2006 | 10:40 AM
JDMCRX's Avatar
Default Re: (monster007)
Nice work canuak
Old Jul 10, 2006 | 10:45 AM
thermal's Avatar
Frankenstein plenum. Good ****. Congrats on the 20 hp gain.....
Old Jul 10, 2006 | 01:09 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
did you do anything special to the middle plate and/or runner inlets? good job on the power production.
Old Jul 10, 2006 | 08:39 PM
monster007's Avatar
Default Re: GSR fab. plenum (not so civic)
The mid plate is machined out and the runners are ported.
Modified by monster007 at 10:48 AM 7/11/2006
Old Jul 12, 2006 | 05:09 PM
nerdsports's Avatar
for 20whp, who gives a **** how it looks
just curious, is the inside of it smoothened out??
Old Jul 12, 2006 | 10:57 PM
monster007's Avatar
Default Re: (nerdsports)
Yes.
Old Jul 13, 2006 | 12:45 AM
RMF
Guest
Posts: n/a
I made one kinda like that too about a year ago for a allmotor guy and it does work good.
Old Jul 13, 2006 | 12:49 AM
.RTErnie's Avatar
Default Re: (RMF)
how did you get that finish on the plenum Randy?
Old Jul 13, 2006 | 08:47 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (RMF)
my guess would be an ultra-fine 3m scotch brite pad and some wd40.
randy needs to make me one as well
monster, if i supplied material and a cad drawing think you could make some hubs for me? i work at a machine shop but we're too slammed to do my work
Old Jul 13, 2006 | 03:15 PM
Hamstr323's Avatar
Default Re: (RMF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF &raquo;</TD></TR><TR><TD CLASS="quote">I made one kinda like that too about a year ago for a allmotor guy and it does work good.
VERY NICE RANDY!
Old Jul 13, 2006 | 03:16 PM
Hamstr323's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hootiehoo &raquo;</TD></TR><TR><TD CLASS="quote">whoa man!
did you like raid a scrap bin?</TD></TR></TABLE>
LOL I was thinking the same thing
Old Jul 13, 2006 | 06:56 PM
Tony the Tiger's Avatar
Monster's design appears to be more well thought... The wide radius entry point where the TB sits would allow much better air distributution than the traditional entry style (cyl #4 gets a wider angle path) -- Similar to the few of the Wilson's intake manifold. The tapered plenum for the 1st cylinder runner is also a good design on Monster's intake, where as RMF's is only a regular capped off end of a pipe
Old Jul 14, 2006 | 12:47 AM
RMF
Guest
Posts: n/a
Default Re: (Tony the Tiger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote">Monster's design appears to be more well thought... The wide radius entry point where the TB sits would allow much better air distributution than the traditional entry style (cyl #4 gets a wider angle path) -- Similar to the few of the Wilson's intake manifold. The tapered plenum for the 1st cylinder runner is also a good design on Monster's intake, where as RMF's is only a regular capped off end of a pipe </TD></TR></TABLE>
Dude ,Do you know anything about intake manifolds?And do you see the taper on mine?I'm not saying anything about who's is better.I am just saying that i made one too and that YES they do work.I also made a bigger one that made more HP but lost alot of TQ.
Also whats good about this style is that you can stack the spacer plates untill you get the correct volume
Old Jul 14, 2006 | 05:13 AM
nowtype's Avatar
Default Re: (RMF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF &raquo;</TD></TR><TR><TD CLASS="quote"> Dude ,Do you know anything about intake manifolds?And do you see the taper on mine?I'm not saying anything about who's is better.I am just saying that i made one too and that YES they do work.I also made a bigger one that made more HP but lost alot of TQ.
Also whats good about this style is that you can stack the spacer plates untill you get the correct volume</TD></TR></TABLE>
How can you make hp but lose torque? The only possible way to do that is increase rpm, but then you are talking about super ghey peak numbers. Its just physically impossible to make more HP at lets say 6000rpm, without increasing torque output.
