Valve Cover Gasket
Old Jul 7, 2006 | 10:11 AM
RaceMyGhost's Avatar
Default Valve Cover Gasket
Ok, im about to do a valve adjustment on my car and general rule of thumb is "you never re-use a gasket". but my question is, will it be ok to reuse my valve cover gasket or should i replace it? the gasket has about 77K on it, but i plan on replacing most gaskets at about 90K. so i will be using it only for about 13K or so...
Old Jul 7, 2006 | 10:48 AM
Rainmaker's Avatar
Default Re: Valve Cover Gasket (RaceMyGhost)
You'll be fine. That one is okay to re-use until it actually starts leaking. I think last time I put some liquid gasket in the corners for a little extra insurance.
Old Jul 7, 2006 | 10:52 AM
DC2 Mang's Avatar
Default Re: Valve Cover Gasket (Rainmaker)
this is one of the few gaskets I re-use quite a bit, I cant be buying new ones everytime i change my valve cover
I havent had a problem yet with re-using the stock one
Old Jul 7, 2006 | 11:03 AM
iH8RICERZ's Avatar
I dont know...you could reuse it but if it starts leaking oil (in the spark plug chamber), or on the outside..then you know its time to replace it. I've been replacing mine every 30+k miles just because I keep taking off my valve cover, getting new valve covers, changing cams, valve adjustments, etc.
Shaguar47
May 28, 2007 08:47 AM
miksew
13
Oct 20, 2006 05:48 PM
-Championship-
Jun 29, 2006 10:59 PM
crx_88_si
Jul 29, 2004 08:47 AM
type Gendy
10
Sep 6, 2003 10:44 AM
