Intake manifold.
Im taking the head off my d16z6 and was wondering how I go about getting the last bottom nut off of the intake manifold. I cant seem to reach it. How do you guys get it off? and when and if I get that nut of do I just pry the two loose with a prybar or screwdriver?
you may have to go from the bottom. We usually just use a uni 12mm & an extention. Also make sure you removed the black brace between the manifold & the block before this nut. That should make it a little easier for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soulforce »</TD></TR><TR><TD CLASS="quote">I finally got the nut loose but im having trouble with the fuel hose going from the fuel filter to the fuel rail. how do I get this off? I already relieved the pressure.</TD></TR></TABLE>
take the hose off from the fuel-filter with a 17mm socket. What's confusing you?
Ryan Lwin
32
Feb 1, 2013 02:23 PM
LS1Bait
Jan 15, 2009 07:04 AM
