half sized radiator will it fit???
It should, you might have to move the mounts around.
But people are always using the stock civic half sizes,
So I don't see why the fluidyne wouldn't work too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg »</TD></TR><TR><TD CLASS="quote">It should, you might have to move the mounts around.
So I don't see why the fluidyne wouldn't work too.</TD></TR></TABLE>
your not suppose too, cuz stock integra is a full size, by having a half size radiator, you will need to rig or cut something so it will hook up properly.. i suggest just buying a full 1
still, your old civic doesnt have the thing for it to stand properly. is like its missing something for it to hold correctly. but imo i would just sell the half size and buy the full size
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumas07 »</TD></TR><TR><TD CLASS="quote">hey i was wondering if fluidynes half core radiator for civics would mount and work on my 99 ls?
thanks</TD></TR></TABLE>
If its a fluidyne you shouldn't have any problems mounting it on.
i believe the one for the del-sol fits in correct, cause the civic ones have different diamter necks, correct me if i am wrong guys not 100 percent sure never had the urge to change my radiator
i got a del sol radiator replica for my '92, to replace the full sized one, it fit ok, not sure on a 99, but the space should be there, i also put on an elctric fan with an independent temp control (autozone $15 for temp controller relay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked »</TD></TR><TR><TD CLASS="quote">yeah, a Del Sol dual core rad will work fine.
I run one in my 94.</TD></TR></TABLE>
ya.. with some little H
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rkrone »</TD></TR><TR><TD CLASS="quote">i got a del sol radiator replica for my '92, to replace the full sized one, it fit ok, not sure on a 99, but the space should be there, i also put on an elctric fan with an independent temp control (autozone $15 for temp controller relay) </TD></TR></TABLE>
did have to move any of the mounts?
