430bhp @ 22psi
Old Apr 19, 2002 | 10:22 AM
austrian type-R's Avatar
Default 430bhp @ 22psi
Today it was my final dyno session. We made a couple of runs and dialed in the cam gear setting + fine tuning the ignition table with the Haltech e6k. The following Plot shows the max numbers of todays dyno runs. The outside temperature was about 20 degres C and the elevation is about 700 meters. This run was with 22psi. It shows 430bhp (374whp). MY tuner said it is not good for boosting always that heavy and the engine will not hold more than 20000 miles with that amount of boost. He looked into the plug holes with some special scope and noticed some detonation signs on the pistons. The sleeves are still fine. He told me to run about 1 Bar daily and I´ll be fine. Maybe boosting 1.3 Bar when it is cold outside for short periods. A dynorun with 1 Bar was showing 350bhp (310whp).
The tourqe is 425 Newtonmeter on the dynoplot below (it is 313 lbs torque)
MY engine has a cr of exact 9.1:1.
Old Apr 19, 2002 | 10:27 AM
Kengs's Avatar
Default Re: 430bhp @ 22psi (austrian type-R)
BTW, what plugs are you using?
Shane, who misses taffelspitz and Meinl kaffe
Old Apr 19, 2002 | 10:28 AM
PM-Performance's Avatar
Default Re: 430bhp @ 22psi (kengs)
nicey nice. good **** man
Old Apr 19, 2002 | 10:31 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Sweet!
And who said FI and ITRs don't mix....
Old Apr 19, 2002 | 10:32 AM
Default Re: 430bhp @ 22psi (itr206)
NGK BCP7ES, stock gap with stock ignition
Old Apr 19, 2002 | 10:34 AM
hungsteR's Avatar
Nicey nice. Man this makes me what to go to the Darkside...
GokuSSJ4's Avatar
very nice !!
Old Apr 19, 2002 | 10:37 AM
ZygSpeed's Avatar
Default Re: 430bhp @ 22psi (Spoon1)
Simply beautiful!
Music to my ears. Ed
Old Apr 19, 2002 | 10:46 AM
done's Avatar
Default Re: 430bhp @ 22psi (Zygspeed)
i bet when vtec engauges, the car just takes off, looka t the jump in hp when vtec engauges, very cool
Old Apr 19, 2002 | 10:50 AM
SEFIxCivic's Avatar
when boosting high i think it would be a good idea to take the gap down to .028 especially since you're not running an ignition.
Old Apr 19, 2002 | 10:57 AM
Splat's Avatar
Collector-o-Guns and Drinker
Simply beautiful!
I bet, Ed! Now you have a goal in sight
Old Apr 19, 2002 | 10:59 AM
Default Re: 430bhp @ 22psi (itr009)
The gap is already very low, this plug comes stock with a very low gap, don`t know the spec. I have no misfire at all, so things are fine.
Old Apr 19, 2002 | 11:01 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
<-------will probably be calling JACK later today
ZygSpeed's Avatar
1 bar seems fine to me.
Old Apr 19, 2002 | 11:40 AM
B2FiNiTY's Avatar
Insane power...
Old Apr 19, 2002 | 11:54 AM
hybrider's Avatar
Default Re: 430bhp @ 22psi (B2FiNiTY)
simply, wow !
Old Apr 19, 2002 | 11:56 AM
done's Avatar
Default Re: 430bhp @ 22psi (hybrider93)
so you daily drive your itr?
Old Apr 19, 2002 | 12:05 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
Is that on a stock B18c5???????
If not list your
Modifications.......tanx
Old Apr 19, 2002 | 12:07 PM
done's Avatar
Default Re: 430bhp @ 22psi (MUTANT X)
no no thats not stock..
Old Apr 19, 2002 | 12:08 PM
ZygSpeed's Avatar
Default Re: 430bhp @ 22psi (Jordo)
Who doesn't?
Old Apr 19, 2002 | 12:31 PM
Type-ARR's Avatar
looks great man....
Old Apr 19, 2002 | 12:37 PM
hooptie157's Avatar
Default Re: 430bhp @ 22psi (TurboR481)
hell yeah, boost is the way to go!!!
Old Apr 19, 2002 | 12:41 PM
slowassR's Avatar
Default Re: 430bhp @ 22psi (hooptie157)
that is a acomplishment
way to go man
Old Apr 19, 2002 | 01:56 PM
Stumpy's Avatar
Default Re: 430bhp @ 22psi (slowassR)
Impressive Stuff!
Old Apr 19, 2002 | 02:14 PM
cheeta's Avatar
Banned
Default Re: 430bhp @ 22psi (Stumpy)
That's badass, sounds like a hell of a setup!
