Main relay Problems, Getting power to relay with good relay but not going to fuel pump?
Ok I ma getting power to the relay, that is the white/yellow wire. I am using good main relay, and I am not getting power to the fuel pump. It is very wierd, It seems as thought there is something that is cutting power in between the power wire going in the relay and the power getting to the fuel pump, and ecu. I have tried to figure this out for 2 days with a honda manual, but nothing has worked as of yet. So what do you make of this mess?
-Brax
-Brax
have you done anything in the engine bay recently? I had a same problem, none of my engine lights would show up though, but i forgot the transmission ground and it started right up
Basic run down.
All the grounds are hooked up.
I can start the car by putting the main power, and ecu/fuel pump wires together.
With the good main relay the car will not start. No fuel pump priming, no spark notta.
Leads me to belive that the Ecu is not sending signal back over to the main relay to prime the fuel pump, Kinda weird.
Hmmanyone know more about the ecu and grounding it?
-Brax
-Brax
