overrev problem(car feels slower also)
Old Jul 6, 2006 | 10:53 PM
purochivas2001's Avatar
Default overrev problem(car feels slower also)
when i shift and step on it, it overrevs about 1k rpm and it feels like it accelerates only after it goes back to normal, due to this the car feels slower, any feed back is appreciated
whats normal idling rpm range??
Old Jul 6, 2006 | 11:14 PM
cgo_62's Avatar
Default Re: overrev problem(car feels slower also) (purochivas2001)
if i understand you correctly, my guess is your clutch is going out; aka slipping
1. shift up
2. step on it
3. rpm goes but car doesn't
4. after a few second, the car finally picks up speed
the answer to your other question is 750 +/- 50 rpm at idle
Old Jul 6, 2006 | 11:24 PM
Default Re: overrev problem(car feels slower also) (cgo_62)
i noticed you live in riverside area cgo_62... do you know of a good shop to get this fixed??...about how much will this run me??
Old Jul 7, 2006 | 12:03 AM
cgo_62's Avatar
i honestly don't know of any shops because i replaced my clutch with the help of couple of grease monkey friends.
shops usually charge anywhere from 45-75 dollars an hour. the job takes about 2.5-3.5 hrs
clutch kits (pressure plate, clutch, bearing) could cost anywhere from $115-400 or more depending on your desire and wallet size.
this is all assuming that your problem is actually the clutch in the first place
Old Jul 7, 2006 | 10:08 AM
i appreciate your help cgo_62... anybody else agree its a clutch problem??
Old Jul 7, 2006 | 10:52 AM
roller3804's Avatar
id say that has all the symptoms of a clutch going out. It could just be you need to bleed the system. And check ur clutch cylinder for fluid.
Old Jul 7, 2006 | 11:23 AM
HS2G's Avatar
Default Re: overrev problem(car feels slower also) (roller3804)
Before we all say its a clutch problem, let me ask how is your driving skills? Maybe when you shift you don't let go of the clutch all the way and step on the gas? This could also cause your RPM to go up because your clutch is still in but once you let it out, the RPM's drop back to its position then start accelerating. Try doing a little burn out or a little launch to see if your clutch still grips well.
Old Jul 7, 2006 | 11:43 AM
soundbomber's Avatar
Default Re: overrev problem(car feels slower also) (HS2G)
HAHA a burnout or launch is not a proper method to determine the condition of your clutch.
in any case, do you often smell heated metal smell?
Old Jul 7, 2006 | 11:19 PM
Default Re: overrev problem(car feels slower also) (soundbomber)
I smell heated metal sometimes....so wats gonna happen if the clutch goes out?? will it damage anything(besides the clutch)??
OttomanK20
Jul 4, 2017 12:43 AM
tianporn
Transmission & Drivetrain
Nov 24, 2010 06:01 PM
efjones9
Apr 29, 2009 10:23 PM
Ri5e
Dec 4, 2001 08:27 AM
