Help! Car throwing P0453 CEL and has a high idle
Old Jul 6, 2006 | 10:26 PM
pumpkyn's Avatar
Default Help! Car throwing P0453 CEL and has a high idle
Ok i ended up doing the mini me swap Y7 Block and Y8 Head also did the Auto to Manual swap at the same time. The car runs p0453 Evaporative Emission Control System Pressure Sensor High Input. Ive read on something that i can trick the ECU with a potentiometer. First does anyone have the full write up on it?
Also my car is idling at about 1200-1500 and when i turn my AC on it goes to 750. Next when i am driving and i put the car in Neutral when comign to a light it dips down to 700 then shoots up to 1500 and bounces between there til i come to a stop then it stays level at about 1200. Could fixing this CEL fix this as well?
3rd when that CEL comes on it idles at about 1600 and sounds like a stutterbox.
Any help would be awesome thanks guys.
Old Jul 7, 2006 | 06:50 AM
pumpkyn's Avatar
Default Re: Help! Car throwing P0453 CEL and has a high idle (pumpkyn)
BUMP
Old Jul 7, 2006 | 09:16 AM
EE_Chris's Avatar
You can't trick the ECU with a potentiometer into thinking an actual FTP is there...you need the hardware if the ECU you're using is looking for a FTP input. Once upon a time 'we' thought it could be done, but it's been proven that it doesn't work. You can find that article over at Katman's website (with my name as a contributor. ).
So you're using a Y8 head, with a Y8 intake manifold with the IACV on the back, along with a 5-spd Y8 throttle body which doesn't have the IACV on the bottom and then all controlled by a 5-spd Y8 ECU??
What year is the car?
Old Jul 7, 2006 | 11:31 AM
pumpkyn's Avatar
Default Re: Help! Car throwing P0453 CEL and has a high idle (EE_Chris)
damn
it is a 97 with a 96 y8 head and ecu
Old Jul 7, 2006 | 02:45 PM
pumpkyn's Avatar
What is katmans website?
Old Jul 7, 2006 | 08:32 PM
pumpkyn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">You can't trick the ECU with a potentiometer into thinking an actual FTP is there...you need the hardware if the ECU you're using is looking for a FTP input. Once upon a time 'we' thought it could be done, but it's been proven that it doesn't work. You can find that article over at Katman's website (with my name as a contributor. ).
What year is the car?</TD></TR></TABLE>
Yes it has Y8 head, IM, and TB. All controlled the P2P ECU
Old Jul 8, 2006 | 09:19 AM
pumpkyn's Avatar
tazeat
10
Dec 3, 2008 09:28 PM
Darkane
Jun 16, 2008 08:41 PM
slacks
Sep 29, 2007 10:27 AM
pumpkyn
Jul 8, 2006 09:20 AM
B00ST2nR
Apr 18, 2003 04:03 PM
