how the hell did this happen?
Old Jul 6, 2006 | 10:22 PM
budget's Avatar
Default how the hell did this happen?
agx-shocks h&r-springs
took my coilovers off and put my springs back on, pulled out of my driveway and went down the street started hearing a clunking noise so i pulled over and the rear passanger side shock tower shot through the top hat and is sitting like a couple of inches above the top hat? i have had a blown shock b4 but how did this one do this?
Old Jul 6, 2006 | 11:01 PM
ikontien's Avatar
you might be missing something on your strut
Old Jul 6, 2006 | 11:40 PM
TruNinja619's Avatar
Default Re: (ikontien)
maybe you didn't tighten the nut enough...
just trying throw some ideas.. I dunno how that happend...
Old Jul 7, 2006 | 04:32 AM
Eddiebx's Avatar
if u mean the strut rod shot through the top hat, then that means you left out a washer.
if you meant the top hat shot through the shock tower, then well you've got a pretty big hole to weld up there.
Old Jul 7, 2006 | 06:24 AM
mugen88crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">if u mean the strut rod shot through the top hat, then that means you left out a washer. </TD></TR></TABLE>
thats it me and my friend left out the key washers that sit on top of the shock which keep them from doing the same thing you described... we scared ourselves shitless. as long as you didnt drive on them to long your fine (the car was just supported by springs). just go back and find that washer!
Old Jul 7, 2006 | 01:04 PM
prelude1897's Avatar
Default Re: (mugen88crx)
This same exact thing happened to someone I know last night, but on the driverside. He has KYB AGX's, and the strut tower tore right through the top hat, so he was rollin on just his spring.
Well, you're pretty much just have to buy a new shock
Old Jul 7, 2006 | 08:25 PM
kala4nia's Avatar
the previous owner did that on my car and it dented the hood(fr driver side) ......sucks
Old Jul 8, 2006 | 05:39 AM
GlenWatkins's Avatar
Default Re: (kala4nia)
Yep..a fairly common event.
Instead of leaving off the factory strut/shock dust shields, you need to cut off the thin steel tube thing and re-install the upper part. Otherwise the strut/shock will pop thru the strut/shock tower.
obuhmyuh
May 15, 2007 08:22 PM
RA73DR
Nov 16, 2005 08:33 AM
thrty8street
Jun 20, 2004 12:14 AM
jDMJeRk
Jun 3, 2004 03:00 PM
Nocturnal
Nov 26, 2003 04:03 PM
