how do i take rear wiper off DA
You can figure out how to take it off on your own. Heres a HT member that sells them
https://honda-tech.com/zerothread?id=1352548
you take off the plastic lining off the hatch from there it will be pretty explanitory taking the motor off from the screws and clips then u have to cut a circle on top of the plastic wiper and remove the nut...u can find the plug for the hatch glass in your engine bay under the batter black rubber piece
take the panels off which are screwed in and pull it off, along with the long ones on the side of the hatch
there are 2 or 3 10mm bolts, remove those
then remove you wiper blade and with a crescent wrench take the neut off the lies underneather the wiper
then unplug the motor and it will fall right out
re install your panels and insert the plug and you will be good to go
the plug from DC4kid is very nice, fits perfect and only $10
FakeJDMEF8
Sep 26, 2004 07:39 PM
