Will an ITR LSD unit fit/work in a B16 tranny?
Old Jul 6, 2006 | 09:31 PM
NickQ's Avatar
Default Will an ITR LSD unit fit/work in a B16 tranny?
Will an ITR LSD unit fit/work in a B16 tranny? Will it work in a GSR tranny?
Any help is appreciated. Thanks!
Old Jul 6, 2006 | 10:02 PM
IceySC's Avatar
Default Re: Will an ITR LSD unit fit/work in a B16 tranny? (NickQ)
im trying to find out just about te same thing b16 quaife in a gsr tranny what is need? not much info on this?
Old Jul 7, 2006 | 02:40 AM
non-VTEC's Avatar
Default Re: Will an ITR LSD unit fit/work in a B16 tranny? (IceySC)
you need a ring gear from a B16 tranny to make the B16 LSD diff work in a GSR trans.
they both have a 4.40 final drive but the GSR tranny ring gear has a different bolt pattern/hole on the ring gear so it will not bolt onto the B16 diff.
i just went through all this a few weeks ago...im using a B16 quaife LSD with in a GSR tranny.......its pretty hard to find the right ring gear......you gotta be careful on what you buy.
Old Jul 7, 2006 | 04:02 PM
NickQ's Avatar
Will an ITR LSD work in a B16 tranny though?
Oh, and thanks for the info!
Old Jul 7, 2006 | 06:05 PM
non-VTEC's Avatar
Default Re: (NickQ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NickQ &raquo;</TD></TR><TR><TD CLASS="quote">Will an ITR LSD work in a B16 tranny though?
Oh, and thanks for the info!</TD></TR></TABLE>
yes it will.......
Old Jul 7, 2006 | 08:08 PM
SkRiBLaH's Avatar
Default Re: (NickQ)
<FONT SIZE="10">NEGATIVE GHOST RIDER</FONT>
the b16 and LS transmissions have a smaller/differant diff. than the GSR/ITR
to put ITR LSD into your b16 transmission, you need a GSR or ITR ring gear (66 teeth)
Old Oct 16, 2006 | 05:58 PM
JerkzEm1's Avatar
Default Re: (SkRiBLaH)
Good info
Old Oct 17, 2006 | 05:38 AM
1fastVX's Avatar
Default Re: (JerkzEm1)
An easy way to get the right ring gear is just to install a JDM ITR 4.7 FD at the same time. That is what I am doing to my tranny right now. Its not that much more $$$ and it saves you the time of sourcing the ring gear...etc.
John
blu00Si
Transmission & Drivetrain
Oct 11, 2013 05:15 AM
hondaboyB18C1
Oct 22, 2007 03:12 PM
crashzerothree
Feb 19, 2007 04:13 PM
Qwikrex
Dec 29, 2002 02:19 PM
