Clutch Pedal squeak, I can't get rid of it.
Old Apr 19, 2002 | 10:08 AM
Honda F1's Avatar
Default Clutch Pedal squeak, I can't get rid of it.
It seems to be coming from the spring area of the pedal. I have tried Wd-40 and it does not work. Anyone know of any good lube or spray that will get rid of the squeak. It happens when I push or release the clutch.
Old Apr 19, 2002 | 10:09 AM
thk's Avatar
thk
Members Only
Default Re: Clutch Pedal squeak, I can't get rid of it. (HONDAF1)
That happened to me awhile back ...
It went away by itself
Old Apr 19, 2002 | 10:24 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: Clutch Pedal squeak, I can't get rid of it. (thk)
its happening to my car right now too...
Old Apr 19, 2002 | 12:22 PM
BDiddy's Avatar
Default Re: Clutch Pedal squeak, I can't get rid of it. (Ross)
mine too. I thought it was something in my clutch...Liek the throwout bearing... But good to hear its not...
Old Apr 19, 2002 | 12:43 PM
Reid's Avatar
Global Moderator
Default Re: Clutch Pedal squeak, I can't get rid of it. (B-DIDDY)
Greasing up the clutch pedal does wonders to remove any noises.
I did this in my 90 Integra and, with a few other tricks, I had an almost-stock pedal engagement even with an ACT Xtreme PP.
Old Apr 19, 2002 | 12:46 PM
SwiftTypeR's Avatar
New User
Default Re: Clutch Pedal squeak, I can't get rid of it. (Reid)
my clutch pedal squeeked too. i replaced the clutch and the noise went away. i looked at my throw out/release bearing and they were toast.
Old Apr 19, 2002 | 12:50 PM
skafia's Avatar
25 Year Member
Default Re: Clutch Pedal squeak, I can't get rid of it. (SwiftTypeR)
When I blew my clutch last year in my GSR the dealer fixed it and my pedal squeaked a lot too. It went away temporarily if I drove my car hard, but once something cooled down it went away.
I took it back, they fixed it, but I forgot what they did
Old Apr 19, 2002 | 01:02 PM
Honda F1's Avatar
Default Re: Clutch Pedal squeak, I can't get rid of it. (skafia)
My sound is definately coming from the pedal not the clutch itself. How and with what do you grease the clutch pedal?
Old Apr 19, 2002 | 01:09 PM
Reid's Avatar
Global Moderator
Grease the parts of the pedal assembly that pivot with automotive grease.
They sell it in big paint-type cans.
Old Apr 19, 2002 | 06:48 PM
kkim's Avatar
I used a teflon based spray lube at all the pivot points and it went away. hasn't been back. name of the spray is Tri flow. also, you sure the noise is not coming from the clutch slave cylinder area, too? good luck. I hate working upside down under the dash.
[Modified by kkim, 5:46 AM 4/20/2002]
Old Apr 19, 2002 | 06:57 PM
sil's Avatar
sil
I have a nearly identical problem with mine in my Si(R). But another thing is that I get this high pitched 'rubbing' sound (or high pitch humming).. when driving in gear, but it goes away right when i press the clutch in.. is this also related to the throwout bearing?? and is the replacement cheap/warrantied, or should i just replace the entire thing?
Old Apr 19, 2002 | 11:19 PM
Honda F1's Avatar
Default Re: Clutch Pedal squeak, I can't get rid of it. (kkim)
Yes I am sure the sound is coming only from the clutch pedal. I can "see" the sound coming from the spring on the clutch pedal. I guess I will try the teflon spray tommorow.
Old Apr 20, 2002 | 05:22 AM
JohnnyBoy's Avatar
It may be in the slave/clutch fork area also....the grease dries up in there...mine squeaked there...couldn't pin point it till I had someone else push the clutch in while I listened.
Old Apr 24, 2002 | 02:35 PM
AoiGSR's Avatar
25 Year Member
Default Re: Clutch Pedal squeak, I can't get rid of it. (JohnnyBoy)
Acura said it was a Throwout bearing that was dried up. They replaced under warranty for me. along with some other stuff that might have caused the squeaking down there. I will get more details soon.
-Aoib0t, who can't hear any squeaking and the cluth pedel feels "ITR" ish now.
Old Apr 24, 2002 | 02:50 PM
Rory Breaker's Avatar
Default Re: Clutch Pedal squeak, I can't get rid of it. (AoiGSR)
I used some Silicone spray and the noise went away...
Old Apr 24, 2002 | 05:02 PM
Honda F1's Avatar
Default Re: Clutch Pedal squeak, I can't get rid of it. (newgsrdriver)
Guess I will try that. If that doesn't work I will have my friend who is a tech at the dealer to fix it.
Old Apr 24, 2002 | 05:08 PM
Ricky Rojales's Avatar
Yup... Silicone spray worked for me, too.
Old Apr 24, 2002 | 05:11 PM
Honda F1's Avatar
Default Re: Clutch Pedal squeak, I can't get rid of it. (Fluoxetine HCL)
Any particular brand that is best?
Old Apr 24, 2002 | 05:37 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
i had the same problem w/ ACT clutches and diaphrams. its not clutch pedal spring.
00BoostedGSR
May 30, 2006 09:09 AM
type_sml
May 16, 2003 03:00 PM
rockwilda
Jun 19, 2002 03:57 PM
eh-D
May 12, 2002 10:00 AM
95TEG
Mar 7, 2002 10:09 AM
