High rpm problems
Old Jul 6, 2006 | 08:08 PM
CRXCIVICMIX's Avatar
Default High rpm problems
We rebuilt the stock 1.5 for right now
it ran great when we started it up
now it idles at 2,300-4,000 rpm
the motor maybe has 150 miles on it
the timing is spot on, all the vac lines are right, plugs, everthing we could think of
any ideas help
Modified by CRXCIVICMIX at 10:37 AM 7/7/2006
Old Jul 12, 2006 | 10:19 PM
Mavrick's Avatar
Default Re: High rpm problems (CRXCIVICMIX)
cold idle valve/tps?
Old Jul 13, 2006 | 06:27 AM
jlicrx's Avatar
vacuum leak somewhere
Old Jul 13, 2006 | 06:37 AM
crx_88_si's Avatar
check the throttle cable and butterfly, might be sticking. Idling @ 4k sounds like more then a vac leak.
next time it is idling @ 4j gently pull up on the gas pedal.
Old Jul 13, 2006 | 06:54 AM
ludesrv's Avatar
Sticky throttle plate, sticky clabe, dirty IAC or the idle screw unscrewed itself.
Take off the manifold plate, look at your TP, sometimes they get so much gunk built up that they stick (my SOHC ZC did it when I first started it up after 3-4 years of sitting). Your cable could be sticking aswell, and easy way to check is if you know the TP is clean, the pedal still stays jammed downwards and can be fixed by pulling back on it, take it off and WD40 that ***** till shes loose.
Sometimes the idle screw will unscrew itself, did it to my SOHC ZC. Simply put some teflon tape around it and screw it back in, adjust (when warm) to where you want it.
JDM-h22a
Oct 20, 2009 10:42 AM
crxnonvtec
22
Sep 3, 2009 02:52 PM
liloldchevyvan
Apr 15, 2008 09:43 PM
CRXCIVICMIX
Jul 7, 2006 10:07 AM
scrubachu
Apr 9, 2005 05:40 AM
