clunk sound over bumps
Old Apr 19, 2002 | 09:46 AM
sloaccord96's Avatar
Default clunk sound over bumps
i probably already know why but wanted a second opinion anyways.
everytime i go over a bump or over a hole or something i would hear a loud clunk coming from my right rear side....either it's the wheels or the exhaust my car's dropped about 2"
maybe i should raise the back a lil higher.
also when i brake i hear squeaky sounds, and grinding sounds....
probably the pads and rotors
what ya guys think?
Old Apr 19, 2002 | 09:48 AM
John's Avatar
New User
Default Re: clunk sound over bumps (sloaccord96)
Do you have coilovers?
Old Apr 19, 2002 | 09:50 AM
Kazmans94cord's Avatar
hmm....dead bodies?
Old Apr 19, 2002 | 10:11 AM
Default Re: clunk sound over bumps (kazmans94cord)
yep coilovers...dead bodies too
Old Apr 19, 2002 | 10:24 AM
4doorH22's Avatar
Oh, boy, each could be so many things. The clunk could be an incorrectly installed spring or shock, something loose in the trunk, bumpstops...
As for the brakes, probably just old rotors and pads... does the pedal or steering wheel shake when you brake?
Old Apr 19, 2002 | 10:31 AM
Default Re: clunk sound over bumps (4doorH22)
doesn't steer, firm control =] just stupid noises
trunk = empty, besides a bottle of 10lb n2o
shocks = kyb agx adjustable , just installed
underneath = custom piping ...thats about 2-3 inches from hitting the ground
Old Apr 19, 2002 | 10:40 AM
John's Avatar
New User
It's likely that the coilover is somewhat dislodging from the upper spring housing (or whatever it's called) when you hit a bump... coilovers really don't fit correctly on Accords, and will do this in the rear when you hit a bump... the sound occurs when it slides back into place. My car does the exact same thing, and it's annoying, but really nothing more than that...
Old Apr 19, 2002 | 12:32 PM
ED8DX's Avatar
Default Re: clunk sound over bumps (DunReit)
try placing a zip tie around the spring and the top seat, if it seems to be that the coil is separating from the seat.
Old Apr 19, 2002 | 12:34 PM
4doorH22's Avatar
Default Re: clunk sound over bumps (crxdx)
https://honda-tech.com/zerothread?id=164396
Old Apr 19, 2002 | 01:37 PM
John's Avatar
New User
Yeah, that's one thing on my long laundry list of minor miscellaneous crap I need to do to my car...
Old Apr 19, 2002 | 02:19 PM
4doorH22's Avatar
you have to drill holes in the "top hat" to do this.
Old Apr 20, 2002 | 10:33 PM
TypeSH's Avatar
is an unseating spring more common in shorter springs or longer springs? Also, how about the perch height? If I move the spring onto a higher perch (so the springs are compressed more initally), would that help solve the problem?
Old Apr 20, 2002 | 10:35 PM
Accord94DX's Avatar
Default Re: clunk sound over bumps (TypeSH)
yup.
ricehero
Dec 4, 2005 05:21 AM
93egSIboi
Feb 1, 2005 04:51 PM
Vtecfool
Dec 29, 2004 12:41 AM
InTeGrA_bLazEd
Oct 9, 2003 03:55 PM
vietboixstunnah
May 10, 2003 01:00 PM
