Mini Me A6 swap... What distributer? Please help!!! Kwik!!!!
I have an EF hatch that I am doing a Mini Me swap with. I am using a OBD0 d16a6 block and OBD1 d16z6 head. I was wondering, I already have the injectors wired up, but what distributer am I supposed to use? The A6 or the Z6? And if I am supposed to use the Z6 dizzy does anyone have a diagram for the OBD1 to OBD0 wiring on it?
Please help!!
Thanks!
Please help!!
Thanks!
Bump TTT anyone? I know these swaps are done all day long!!! Someone has to know what dizzy to use....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by *****: JDMCoveralls »</TD></TR><TR><TD CLASS="quote">I have an EF hatch that I am doing a Mini Me swap with. I am using a OBD0 d16a6 block and OBD1 d16z6 head. I was wondering, I already have the injectors wired up, but what distributer am I supposed to use? The A6 or the Z6? And if I am supposed to use the Z6 dizzy does anyone have a diagram for the OBD1 to OBD0 wiring on it?
Please help!!
Thanks!
</TD></TR></TABLE> The basic way this works is that if you run an OBD-0 ECU, you have to use an OBD-0 distributor regardless. The internal electronics are different and the same runs for an OBD-1 ECU and distributor; either convert to OBD-1 and use the Z6 distributor or stay OBD-0 and make the A6 distributor work.
Please help!!
Thanks!
I forgot to mention that I am using an P28 with a jumper... So in that case I need to use the Z6 dizzy. So does any know how to convert the Z6 dizzy to OBD0?
Any diagrams?
I know the two wire plug you can just splice together...
But the other plug has like 6 or 7 wires. So I need specifics...
Thanks so far!
Keep er coming!
Any diagrams?
Thanks so far!
Keep er coming!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by *****: JDMCoveralls »</TD></TR><TR><TD CLASS="quote">I forgot to mention that I am using an P28 with a jumper... So in that case I need to use the Z6 dizzy. So does any know how to convert the Z6 dizzy to OBD0?
Any diagrams?
Thanks so far!
Keep er coming! </TD></TR></TABLE>
BUMP TTT!!!!!!! SOMEONE???????????????????!!!!!!!!??????
Any diagrams?
Thanks so far!
As in the FAQ --> https://honda-tech.com/zerothread?id=1349052
