Searched Turn Signal problem!
Old Jul 6, 2006 | 05:57 PM
trrbl1bmx's Avatar
Default Searched Turn Signal problem!
I was riding home from work today and I went to switch lanes and noticed that I had no blinkers. I replaced the flasher. Still nothing. Is there another relay somewhere else that would cause this. BTW stock dash and everything, nothing has been altered. ( 1991 Civic Si )
Old Jul 6, 2006 | 05:59 PM
philkehn's Avatar
are you bulbs burnt out lol i would say get a test light and test your wires running to the blinkers to see if they are getting power when you hit your blinker switch, if you are getting power its not your relays more likely a wire and bulb problem, possible a small electrical fire that you didnt notice?
Old Jul 6, 2006 | 06:17 PM
trrbl1bmx's Avatar
I'll check the bulb. But if just one bulb burnt out, why would that cause everything to die. Including the little lights on the instrument cluster.
Old Jul 6, 2006 | 06:25 PM
trrbl1bmx's Avatar
Ok, checked the bulb.., the fuse is good, I mean what else could it be. I'll have to check it with a test light tomorrow when I get off of work. Is there any other relay besides the flasher?
Old Jul 6, 2006 | 06:30 PM
FernEF's Avatar
Default Re: (p00n)
check your fuses. same thing happen to me once
Old Jul 6, 2006 | 06:45 PM
trrbl1bmx's Avatar
Default Re: (FernEF)
check all fuses and they are all good
Old Jul 6, 2006 | 08:57 PM
philkehn's Avatar
i believe the flasher is the only relay but if it has something to do with your guage lights it sounds like a short or a blown fuse just try it out with a test light and see what you get
Old Jul 10, 2006 | 04:14 PM
trrbl1bmx's Avatar
i have checked and replaced everything. flasher ( new ) fuse ( new) bulbs ( new ) my question now is, Is there a switch inside the steering column?
Old Jul 10, 2006 | 06:26 PM
1989CivicSi's Avatar
Default Re: (p00n)
Combo switch? My best guess if you've checked everything else including wire continuity.
Old Jul 10, 2006 | 06:37 PM
C1CRX's Avatar
Traffic signal tech
Default Re: (1989CivicSi)
these work great
Old Jul 10, 2006 | 06:39 PM
trrbl1bmx's Avatar
yep. lights work fine just no turn signals or hazards
Old Jul 10, 2006 | 06:46 PM
trrbl1bmx's Avatar
Default Re: (lvcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lvcrx &raquo;</TD></TR><TR><TD CLASS="quote">these work great
hahahahahah thats the best
Old Jul 10, 2006 | 06:47 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (p00n)
Old Jul 10, 2006 | 07:46 PM
trrbl1bmx's Avatar
thanks! real helpful. Anyone know where a possible bad ground could be coming from in this situation.
Old Jul 10, 2006 | 07:50 PM
jdeemseerx's Avatar
i believe the grounds for the headlights and signals are at the front corner on each side of your engine bay.. they are covered by a clear plastic looking thing
papi123
Honda Civic (2001 - 2005)
Aug 19, 2014 09:11 AM
RemoveGiantWingOnYourCar
Nov 2, 2006 06:13 PM
si90rex
Aug 10, 2006 09:54 AM
Ming Tsai
Sep 30, 2003 06:43 AM
EGTeK
Mar 26, 2003 10:52 AM
