new clutch is in
Old Jul 6, 2006 | 05:06 PM
JDMPaulWall's Avatar
Default new clutch is in
whats up guys, need alittle help. About a week ago I made a post about Hmotors and how they sent me a screwed clutch. I just got the new clutch in and ready to go and it refuses to go into gear, any ideas on what the hell is going on ?
Old Jul 6, 2006 | 05:58 PM
yellowrexsi's Avatar
Default Re: new clutch is in (JDMPaulWall)
did you bleed it good??
Old Jul 6, 2006 | 06:05 PM
Dartanian's Avatar
Default Re: new clutch is in (yellowrexsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowrexsi &raquo;</TD></TR><TR><TD CLASS="quote">did you bleed it good??</TD></TR></TABLE>
Huh? A clutch job does not require the hard lines to be removed at all, so bleeding isn't necessary.
Did you make sure everything was installed correctly?
Old Jul 6, 2006 | 06:10 PM
Default Re: new clutch is in (Sleeper Style)
9 out of 10 mechanics will remove the tranny to get to the clutch. So most the time you will need to bleed it. I personally unbolt the lines so that the hard lines don't get damaged
Old Jul 6, 2006 | 06:20 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowrexsi &raquo;</TD></TR><TR><TD CLASS="quote">9 out of 10 mechanics will remove the tranny to get to the clutch. So most the time you will need to bleed it. I personally unbolt the lines so that the hard lines don't get damaged</TD></TR></TABLE>
10 out of 10 mechanics will remove the tranny to get to the clutch. There is no other way.
A tranny isn't bled. The fluid is drained before removing it and refilled when reinstalling it.
Trust me, I have done several clutch jobs, so either you are confused, or have no idea what you are talking about.
Old Jul 6, 2006 | 06:33 PM
JoePSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeper Style &raquo;</TD></TR><TR><TD CLASS="quote">10 out of 10 mechanics will remove the tranny to get to the clutch. There is no other way.
Trust me, I have done several clutch jobs, so either you are confused, or have no idea what you are talking about.</TD></TR></TABLE>
ript
Old Jul 6, 2006 | 06:37 PM
what the expletive are you talking about, Bleeding a clutch has to be done with the tranny on after it is all installed. It has to be done, the little bleeder screw on the front of the tranny has to be opened with the clutch pedal pressed.
You don't bleed a tranny you ***, you bleed the fluid out of the clutch system
Old Jul 6, 2006 | 06:40 PM
DC4_MADMAN's Avatar
I hope he is referring to bleeding the slave cylinder, but even if he is he would still be incorrect. The slave cylinder just gets unbolted from the trans and moved out of the way for trans removal.
Sounds like he has been doing it the hard way.
Old Jul 6, 2006 | 06:41 PM
DC4_MADMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowrexsi &raquo;</TD></TR><TR><TD CLASS="quote">what the expletive are you talking about, Bleeding a clutch has to be done with the tranny on after it is all installed. It has to be done, the little bleeder screw on the front of the tranny has to be opened with the clutch pedal pressed.
You don't bleed a tranny you ***, you bleed the fluid out of the clutch system</TD></TR></TABLE>
Then you been doing the HARD incorrect way. Refer to my post above.
Old Jul 6, 2006 | 06:44 PM
Default Re: new clutch is in (4door_demon)
just seen that, hence the confusion.
I always remove the slave cylinder, it only takes a few seconds to bleed it. I personally would rather do that then break or bend a line
Old Jul 6, 2006 | 06:47 PM
Dartanian's Avatar
You are an idiot. Please stop posting.
I never said you bleed a tranny. And no, the clutch fluid does not have to be done, unless you do it your way...the wrong way.
Whatever, I am done arguing with you over something as retarded as this. I hope you feel special.
Old Jul 6, 2006 | 06:49 PM
do you know if he did it the "correct way"
all I did was offer a simple solution. Take it or leave it
not all of us are honda gods
Old Jul 6, 2006 | 07:15 PM
RHDintegXsi's Avatar
well anyhow to the op..your best bet is to double check and make sure the slave is properly bled and then go from there..check the simple stuff first
Old Jul 6, 2006 | 11:10 PM
Fat Chick Magnet's Avatar
pwned
Old Jul 7, 2006 | 12:16 AM
Default Re: new clutch is in (dc2rtek)
haha yea, I bleed the lines.
meagainsttheworld
Aug 30, 2006 05:53 PM
teggy2154
Nov 15, 2005 10:33 PM
one slow coupe
19
Jan 10, 2005 08:46 PM
90hatchie
Nov 10, 2004 12:04 PM
HybridGSR1
Jul 24, 2003 07:15 PM
