Why do DEI alarms remote start when power is removed and re-connected?
Old Jul 6, 2006 | 09:10 AM
suspendedHatch's Avatar
Default Why do DEI alarms remote start when power is removed and re-connected?
I've been noticing this a lot lately when I R&R cars at my work. If I pull the fuse or unplug the harness to the alarm, then reconnect it, the alarm triggers the remote start sequence. Why the hell would DEI set it up like this.
Modified by suspendedHatch at 10:50 AM 10/21/2006
Old Jul 6, 2006 | 12:43 PM
RHDintegXsi's Avatar
Default Re: Why do DEI alarms remote start when power is removed and re-connected? (suspendedHatch)
i didnt know about that but i have noticed that when the car battery droppes really low remote start kicks in..scary either way
Old Jul 6, 2006 | 02:11 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Why do DEI alarms remote start when power is removed and re-connected? (SINFULintegXsi)
Its the microprocesser in the alarm unit, I seen this with real cheap alarms. I rarely see it with dei. But is has happend with dei twice, If you keep the hood opened-if there is a hood pin- and use the switch thats suppose to kill the ground to the remote start unit it won't happen. Not saying it might not but it helps.
Old Jul 6, 2006 | 07:32 PM
Default Re: Why do DEI alarms remote start when power is removed and re-connected? (wrx-killer-Sti eater)
Yeah the hood pin kills it as long as it's still good, but on some aged installations, the hood pin is no longer grounded.
This is one of the reasons why I'm not satisfied with DEI alarms, although I do tend to favor them since there isn't much competition.
Old Jul 6, 2006 | 07:43 PM
lol, you can't blame dei for the hood pin, the electronics are good. But the hood pin still needs to be inspected from time to time. I tell customers to wd-40 them every 6 months or so and to test them out. You know some theives like to prep. also what about the switch thats is suppose to be installed to kill the remote start. blk/wht. There is suppose to be a switch so when the car is being worked on it can be defeated. But you know how that goes, some people are lazy.
Old Jul 6, 2006 | 09:00 PM
redteg96's Avatar
my clifford matrix came with a sticker that said when the battery gets disconnected the car will attempt to auto start lol
Old Jul 6, 2006 | 09:28 PM
Default Re: (redteg96)
they all come with that red and white sticker, matter of fact most that have remote start have that sticker. It mandatory by a law for them I just found out.
Old Jul 7, 2006 | 01:35 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">they all come with that red and white sticker, matter of fact most that have remote start have that sticker. It mandatory by a law for them I just found out. </TD></TR></TABLE>
Its also supposed to have a hood pin.
Old Oct 10, 2006 | 01:37 PM
alex801to410's Avatar
when the remote start sees a fluctuation in voltage the brain believes that you are ingaging the remote start sequence. If a hood pin is installed then you would not have this problem happen.
216.226.142.95:27016
Audio / Security / Video
Aug 26, 2008 08:21 PM
Kyles ej1
10
Sep 7, 2006 11:03 AM
kon
11
Oct 21, 2005 12:54 PM
94TealCivic
Jul 12, 2003 01:57 AM
Weston
Jan 30, 2002 04:01 PM
