will a B20 valve cover fit on a LS head?
Old Jul 6, 2006 | 06:11 AM
Flexin5's Avatar
Default will a B20 valve cover fit on a LS head?
looking for some quick help, i have a 94 motor with the older style valve cover, i know you can put the 96+ valve cover on it, but i was told that a B20 valve cover won't work? is this true? thanks in advance
Old Jul 6, 2006 | 06:15 AM
inline4's Avatar
Default Re: will a B20 valve cover fit on a LS head? (Flexin5)
it's the same valve cover as an LS. both have p75 heads.
Old Jul 6, 2006 | 06:34 AM
Flexin5's Avatar
that's what i though. thanks man.
Old Jul 6, 2006 | 07:27 AM
trick_db's Avatar
Default Re: will a B20 valve cover fit on a LS head? (inline4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inline4 &raquo;</TD></TR><TR><TD CLASS="quote">it's the same valve cover as an LS. both have p75 heads.</TD></TR></TABLE>
is the same cover, but the head code is not p75 for b20
Old Jul 6, 2006 | 05:34 PM
inline4's Avatar
Default Re: will a B20 valve cover fit on a LS head? (trick_db)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trick_db &raquo;</TD></TR><TR><TD CLASS="quote">is the same cover, but the head code is not p75 for b20</TD></TR></TABLE>
yes it is, on most of them. the only time it is different is if it has a pr8 head, and those are the rare b20 heads.
whats the head code for b20's? since you think it's not p75, im curious.
Old Jul 6, 2006 | 05:39 PM
Danziver's Avatar
It should
Old Jul 6, 2006 | 05:43 PM
trick_db's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inline4 &raquo;</TD></TR><TR><TD CLASS="quote">yes it is, on most of them. the only time it is different is if it has a pr8 head, and those are the rare b20 heads.
whats the head code for b20's? since you think it's not p75, im curious.</TD></TR></TABLE>
so your saying b20 and ls head are both p75? hmm?
not really sure but it shouldnt be or well the valve cover match tho
Old Jul 6, 2006 | 07:53 PM
b20powereDA's Avatar
yes bothe heads are p75 kinda like b16 and type r is pr3. and to the op yes the valve cover will fit
chicka
Apr 5, 2017 07:53 AM
z06eateR
Sep 22, 2010 12:26 PM
mrxracing
Oct 28, 2004 01:34 PM
