upgrading cams
Old Jul 5, 2006 | 11:05 PM
jonathan13's Avatar
Default upgrading cams
when you upgrade to just stage 1 cams do you have to upgrade valve springs and retainers? also do you need adjustable cam gears or will stock work?
EDIT: lets put it this way.. what are the chances of me floating a valve if i dont upgrade the springs and retainers?
Modified by jonathan13 at 12:43 AM 7/6/2006
Old Jul 5, 2006 | 11:43 PM
jonathan13's Avatar
Default Re: upgrading cams (jonathan13)
bump
Old Jul 6, 2006 | 12:17 AM
mtber's Avatar
This all depends on how agressive the cams are & how high you are reving the setup.
I would recommend upgrading atleast the intake valvesprings to a dual valve spring setup.
Cam gears will help if you plan on having the car dyno tuned.
I would recommend you get a skunk2 / blox intake manifold if you don't already have one.
Old Jul 6, 2006 | 12:35 AM
jonathan13's Avatar
Default Re: upgrading cams (mtber)
i will only be revving to stock rev limiter.. and i just want stage 1 cams.. what are my chances of floating a valve? i would upgrade to dual valve springs and reatainers but then i wouldnt have the money for the cams lol
Old Jul 6, 2006 | 01:26 AM
jonathan13's Avatar
bump
Old Jul 6, 2006 | 01:45 AM
b00sted_hatch's Avatar
Little Hercules
if you run stage 1 cams you wont have to worry bout floating a valve. they wont be to aggressive. get some ITR cams man! those are the best! for N/A or boost setups. ive done both
cleanep3
Jun 15, 2010 06:12 AM
b18 hatch mike
Jul 8, 2007 11:56 AM
CRXSleeper
Sep 9, 2002 10:47 PM
B00ST2nR
Aug 17, 2002 10:28 PM
