oki dont know whats going on
Old Jul 5, 2006 | 09:52 PM
gsr_civic94's Avatar
Default oki dont know whats going on
ok so now its getting spark its in time and its getting gas but it still wont start WTF!!!!!!!!!!!!!!!!!!!!!!!! when i turn it over its got this weird *** smell to it its acting like it wants to crank up and run and i know its got good compression cause you can here it popin threw the exhaust im confused please help
Old Jul 5, 2006 | 11:05 PM
ALLMOTORCRX20's Avatar
Default Re: oki dont know whats going on (gsr_civic94)
The first thing i would do is make sure that the spark plug wires are in the correct order. If you said you have fuel, spark and compression, I dont see what else could be wrong with your car.
Also, make a compression test on the car and make sure it has good compression. Never assume a car has good compression.
If the compression is good and the spark plug wires are in the correct order, take the spark plug wire out where it connects to the spark plug and put another spark plug at the end and ground it. Make sure to grab the wire at the boot at the very top. When its grounded, have someone crank the car to make sure there is spark.
anht
13
May 1, 2010 11:57 AM
ferio252
Dec 30, 2008 06:47 PM
themex77
Feb 17, 2007 02:29 PM
NegativeXero
11
Aug 18, 2006 06:52 PM
_gurusan_
Mar 13, 2005 02:33 PM
