Looped lines now check engine and ATTS lights
Old Jul 5, 2006 | 07:34 PM
kornerk12's Avatar
Default Looped lines now check engine and ATTS lights
I removed all the power steering components and followed 98vtec's guide in FAQs. Anyway i had to leave one sensor disconected that was hooked up to the high pressure line. I have no idea why i am getting a CEL. Any ideas ? Should i reset the ecu ?
Old Jul 5, 2006 | 09:21 PM
kornerk12's Avatar
Default Re: Looped lines now check engine and ATTS lights (kornerk12)
bump..... i drove the car around everything feels ok but i still have the CELS
Old Jul 5, 2006 | 10:04 PM
98vtec's Avatar
moderator emeritus
i never said it would work on an SH. I have a feeling that the sensor is some kinda reading for the ATTS system and since the "high pressure" line is no longer high pressure, then thats why you are getting an atts light.
edit:
added a warning to my thread
Modified by 98vtec at 1:17 AM 7/6/2006
Old Jul 5, 2006 | 10:38 PM
kornerk12's Avatar
Default Re: Looped lines now check engine and ATTS lights (98vtec)
idc if my atts is disabled because i will be running hondata very soon anyway which will disable it. But in the meantime will this hurt performance ? When hondata is installed will this code hurt performance ?
Old Jul 6, 2006 | 04:18 AM
soundbomber's Avatar
which check engine lights? when you get hondata i'm doubt it will look for whatever code's it's throwing so all you'll be dealing with is the atts stuff.
Old Jul 6, 2006 | 04:43 AM
98vtec's Avatar
moderator emeritus
you are referring to the ATTS light and not the CEL right?
Old Jul 6, 2006 | 05:07 AM
vinuneuro's Avatar
If your cel is on, your atts light will be automatically on as well. If it were an atts problem, the cel light up. Pull the code(s).
VTEC Visions
Mar 6, 2005 07:27 PM
digital sol
Sep 18, 2004 08:11 PM
Rdriver
Jun 2, 2004 05:57 PM
wade
Dec 24, 2003 06:25 AM
