what color are the wires going into the IAT and IAC on my 96 gsr?
after adding my 3 bar map, resistor box, and victor x mani ect ect my harness is all over the place well im throwing codes 10 and 14 which are IAC and IAT they were working before so im thinking i might have switched them around with the wrong plug just want to be sure ive atleast got them hooked up right then i will worry about replacing them if needed thanx
thanx a lot hopefully its a simple problem thats as easy as swapping the plugs and re-setting the ecu if not oh well i have tons of sensors around i will just start swapping them in till they go away. thanx echo
brakedrum
Oct 16, 2010 08:57 PM
