egr valve
lol, where is the egr valve. i had a h22 easy to find, but where is it on the b18c ?
reason why i ask i wanted to fix my crazy idol, i think the b16 do not have them, so im guessing b18c does not as well, but hoping it does. if it does not have a egr valve how do i fix my crazy idol i can not stand it any more.
no im not throwing any codes and no leak, i reallly wanna fix this idol. any other idea, i could i fix my iacv would the sensor be bad any one else with a crazy idol on a gsr motor, how did u fix the idol
The IACV should have two rubber hoses going into it and a sensor. Its located on the back of the intake manifold. Take some brake cleaner and clean it out. That should help your idle.
Here is a nice write up on it. https://honda-tech.com/zerothread?id=1575913
If it's just your idle you can adjust it, but it can be other things causing your idle acting up. Bad spark plugs, bent valves, bad distributor cap or rotor can all to lead to your problem.
