Compression ratio formulas?
I just did a compression check yesterday and I was wondering if there is any way to take those numbers and find out what your compression ratio is. My numbers were 225/230/227/229. I realize you can do it with bore,stroke,head cc's, gasket thickness, deck height, #of cylinders etc. But is there any way to use the numbers from a comp. test.
[Modified by stretracr, 7:20 AM 4/19/2002]
http://www.c-speedracing.com/howto/c.../compcalc.html
This is a compression ratio calculator. It does not use the results of a compression test but it uses the block/piston/gasket... combination to give you your CR.
You have similar compression numbers them me and I am theoritically running 11.4:1 ratio (just to give you a reference).
Edit: Ooops I did not read the last part of your first post
I am not helping you at all...
[Modified by JPP, 11:26 AM 5/7/2002]
I am not helping you at all...[Modified by JPP, 11:26 AM 5/7/2002]
a brand new stock block can have 240psi ...
Greg
NOPE, doesnt work like that.
Greg
Greg
As I mention above, I am running 11.4:1 CR and yet the highest pressure I see is 230 PSI (which below the pressure seen on a blue printed, stock CR engine).
pV=nRT
you forgot the number of moles
_
R divided by M, the molar mass of the gas in question
if you use big V like you did, you need the 'n',
_
and R has to have a bar over it (R) to signify molar units.
as you can tell i have had to much thermodynamics this semester
Nisif
Apr 12, 2005 09:13 AM
