My ABS Control Unit blows up
Old Jul 5, 2006 | 03:39 PM
emegge's Avatar
Default My ABS Control Unit blows up
I was searching in the inet, fot the led ABS in the dash comes on eventually.
I jumped the DLC and gave the code 81 that means the Central Processing Unit and ROM/RAM diagnostics has a problem:
ABS Indicator Is On With DTC 81
SYMPTOM
ABS indicator light is on with ABS DTC 81 [Central
Processing Unit (CPU) Diagnosis, and ROM/RAM
Diagnosis] stored.
PROBABLE CAUSE
ABS control unit malfunction.
CORRECTIVE ACTION
Replace the ABS control unit.
PARTS INFORMATION
ABS Control Unit:
P/N 39790-S84-A02, H/C 7054224
Anybody knows for what reason this happened? and where I can buy a new/used ABS Control Unit
My car is a Honda Accord 1998 EX
Old Jul 6, 2006 | 05:58 AM
emegge's Avatar
Default Re: My ABS Control Unit blows up (emegge)
Old Jul 6, 2006 | 06:11 AM
khunt0012's Avatar
Meat Robot Invisible
Are you sure it's the control unit that screwed up? I know on some Accords wheel speed sensors were the cause of alot of malfunctioning ABS units. But to my knowledge thats a totally different code.
Looks like it's about 200$ for the control unit:
http://www.slhondaparts.com/se...se%21
Old Jul 6, 2006 | 10:16 AM
emegge's Avatar
Default Re: My ABS Control Unit blows up (khunt0012)
well, I don't know about the ABS, but if the any speed sensor may said that the ABS control unit is blow out, I gonna check the each sensor, looking Moisture in the sensor.
what is the common reasons that the speed sensors present problems?
Old Jul 6, 2006 | 10:39 AM
khunt0012's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emegge &raquo;</TD></TR><TR><TD CLASS="quote">well, I don't know about the ABS, but if the any speed sensor may said that the ABS control unit is blow out, I gonna check the each sensor, looking Moisture in the sensor.
Because they are garbage on the Accords. They tend to break very easily. Personally when I go to paint my car the ABS will be coming out anyways, so no skin off my back.
Old Jul 6, 2006 | 10:49 AM
emegge's Avatar
thanks, I will change the four sensor ( is cheapest) And soon I will try to review the control unit and to observe the codes that present/display to me
bgioan
Sep 6, 2011 05:30 AM
gnx547
Oct 31, 2010 05:54 PM
darockstar
Mar 11, 2006 07:26 PM
dgrave
Apr 20, 2005 11:36 AM
CaMiKaZi
Apr 12, 2003 08:30 PM
