FS: (NY) suspension techniques integra type r ITR speedtech sway bar/tie bar/sub frame reinforcment
The part number for this kit is 53152
I am selling a suspension techniques ITR speedtech sway bar/tie bar/sub frame reinforcement kit that I bought for my LS but it doesnt fit the chasis... so never installed. If you have a swaybar kit you'd like to trade for this one, let me know... this might also fit the chasis of an EG
will sell it for $260 shipped firm... kit costs like $300 shipped new and mine is brand new never installed
**UPDATE, PICS ADDED**
Modified by jweezy225 at 7:22 AM 7/8/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njandrewg »</TD></TR><TR><TD CLASS="quote">shouldnt it fit if you have a BSQ adaptor kit for using a Type R rea sway bar on a LS/GS/RS? You should just run that instead.
How big is it anyways?</TD></TR></TABLE>
what bsq kit would make this work? explain please... its 22 mm thick
http://www.geocities.com/bretq/mounting_kit.html
thats for the type R rear sway bar install. Are the brackets on your kit |) flush or like stock on the integras?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njandrewg »</TD></TR><TR><TD CLASS="quote">tahts because the kit is for a type R, does it line up to one of the 10mm bolts on the bottom? With the BSQ kit you enlarge those holes and put a bolt thru there</TD></TR></TABLE>
yes, all of the other holes line up just fine... so your saying the bsq kit will help me make that kit fit? explain how if you can... like, if I enlarged the holes then how would I get the bolt to stay?
here are instructions for the type R sway bar install on a non type R teg
http://geocities.com/bretq/swaybar_install.html
pretty much you enlarge the hole, and put in a bigger bolt thru, the bracket and spacer, then on the other side you put a washer(provided with the kit) and a locking nut, so its nice and in place.
hmm those are alright, but im not just installing the bar, im trying to install the tie bar and reinforcement plate... so as u can see in the pictures, the holes dont line up, you know?
depends on how similar the EK chasis is to a type r... if not you can drill holes, but I just dont feel like drilling the holes into my subframe, i'd rather try to buy something new, but this is still a great product at a good price here
put on ebay today: http://cgi.ebay.com/ebaymotors...%3AIT
