fule pump wont turn on
Old Jul 5, 2006 | 10:11 AM
NSfit's Avatar
Default fule pump wont turn on
my car wont start because the fule pump is not turning on. besides the connections on the pump where are the other connections? also what else should i look for?when you turn the ignition there is no buzz from the pump turning on.
Old Jul 5, 2006 | 11:51 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: fule pump wont turn on (NScivic)
you either have no spark, or the main relay has crapped out.
Old Jul 5, 2006 | 11:52 AM
Discosteak's Avatar
i can almost garauntee its your main relay, it is a common problem. the relay can be repaired all you have to do is take off the cover on the relay and resolder the pins on the p/c board the broken solder connection will have a ring aroud it inside the solder joint.
Old Jul 5, 2006 | 11:53 AM
Discosteak's Avatar
Default Re: fule pump wont turn on (boostedcivicsir)
having no spark has nothing to do with the fuel pump not priming
SkoundrelUSA's Avatar
cute little bastard
Do your cluster lights light up when you put the key in the last position?
Old Jul 5, 2006 | 12:03 PM
byronl's Avatar
this is the inside of the main relay, you can see a faint white ring on the solder joint.
jdm b18c ek4's Avatar
Default Re: fule pump wont turn on (SkoundrelUSA)
mine did the same thing, and it was my main relay... check that
Old Jul 5, 2006 | 01:57 PM
NSfit's Avatar
Default Re: fule pump wont turn on (jdm b18c ek4)
yes all cluster lights turn on. i can turn the car ignition on and off like 20 times and it will prime like once, but its a bitch today to move my car for street sweeping it took me like 5 miniuts
Old Jul 5, 2006 | 04:42 PM
cute little bastard
then its probably main relay. I have one for 10 shipped
Old Jul 5, 2006 | 04:52 PM
Whig-it's Avatar
Also check the ground on the t-stat housing, if it's not tight, no fuel pump
Old Jul 5, 2006 | 05:05 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
have you checked all of the fuses. I seen people that tried to do fuel pump kills blow fuses. Also does the car have a kill switch that you might not of know about because this happens alot.
Old Jul 5, 2006 | 05:26 PM
ekb16's Avatar
try checking ur grounds...thats one thing that will make ur fuel pump not prime...i swaped my motor one time and i only grounded one spot and couldnt figure out why fuel pump wasnt priming...then i grounded 2 other spots it started working again
Old Jul 5, 2006 | 05:29 PM
FalkenSiR's Avatar
Default Re: (ekb16)
check fuses
check main relay
it's one of those 2
Old Jul 12, 2006 | 10:47 AM
NSfit's Avatar
Default Re: (fast95eg8)
where is the main relay located?
Old Jul 12, 2006 | 10:54 AM
cute little bastard
Default Re: (NScivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NScivic &raquo;</TD></TR><TR><TD CLASS="quote">where is the main relay located?</TD></TR></TABLE>
I'm guessing you have a 92-95 Civic?
its to the left of the interior fuse box (by driver's side lower dash)
There will be a 10mm thats holding it onto the dash. Should be a grey looking box
FSK1460
Sep 29, 2010 01:00 PM
acidburn2k2
Aug 16, 2010 09:08 AM
SiR-G DC
Aug 20, 2009 08:04 AM
HawaiiCrx
Jan 6, 2003 03:04 PM
