What to glue side window glass into bracket with? Silicone?
Old Jul 5, 2006 | 10:00 AM
Jonathan_ED3's Avatar
Default What to glue side window glass into bracket with? Silicone?
I'm replacing my power door lock motors/regulators on my sedan, and when I pulled out my window glass I noticed one of the two brackets that attaches itself to the glass has pulled off.
It looks like it was originally glued on with silicone or something.
What do I use to glue it back on with? I only want to do this once!
Old Jul 5, 2006 | 10:14 AM
cbp_crx's Avatar
Default Re: What to glue side window glass into bracket with? Silicone? (Jonathan_ED3)
in for an answer i have the same problem
Old Jul 5, 2006 | 10:20 AM
Someone help..it's about to rain
Old Jul 5, 2006 | 10:45 AM
Outsane's Avatar
Default Re: (Jonathan_ED3)
window glass sealant.. just like they use to put the front windsheild on..
if you take it to a place that puts windows unless they are money grubbin..
they should give a dab for free..
I wouldn't use silicone since its not that strong in shear..
compared to the stuff thats was originally on there..
could use liquid nails too...from home depot or dixieline..
Old Jul 5, 2006 | 12:27 PM
Crx Jimmy's Avatar
Default Re: (Outsane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane &raquo;</TD></TR><TR><TD CLASS="quote">window glass sealant.. just like they use to put the front windsheild on..</TD></TR></TABLE>
I tried that and when it gets real hot it would come unglued, i ended up using some stuff called GOOP has worked for a couple years now
Old Jul 5, 2006 | 12:39 PM
well in an effort to beat the rain, i used an extra strength two part epoxy. It seems to be holding up fine. Hopefully it will do alright long-term. I also lubed up my weatherstrip channels to make everything move easier.
Old Jul 5, 2006 | 12:52 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
That should work..
In the past,I have used a two part epoxy product called "quik-steel"
for this with very good results as long as it is "fresh"..
IE: if it has not been on the shelf too long..
It tends to get hard and brittle with age..
See: http://people.consolidated.net....html
{the one at the very top}
You can also add extra support/epoxy around the edges of the
brackets since the area can't be seen..
Old Jul 5, 2006 | 12:55 PM
I've noticed the Permatex "Plastic Weld" also sucks a nut if it's not fresh. I've never used their Quik Steel though.
Old Jul 5, 2006 | 01:52 PM
Clean88crx's Avatar
I used silicone about 2 months ago, still holds fine.
jmai86
Feb 11, 2012 05:37 AM
240MANSX
Dec 12, 2007 10:09 AM
satintegra
Nov 27, 2006 08:25 PM
civiccoupe94
16
Dec 27, 2005 04:01 PM
0ptimus prime
Mar 16, 2004 09:37 AM
